I need some help understanding a problem regarding Friction Force.
When standing on a skateboard and walking along its length, the skateboard moves in the opposite direction due to the backward force exerted by the person walking. This phenomenon is explained by Newton's third law of motion, where every action has an equal and opposite reaction. The static friction coefficient is sufficient to prevent slipping, allowing the skateboard to move backward instead of remaining stationary. The discussion also touches on the participant's intention to explore further physics questions after their exam. The conversation concludes with a sense of camaraderie and shared interest in physics.
patowlmc
This problem is regarding Friction Force:
Imagine a skateboard, low and with well-oiled bearings. What would happen if, standing over it at rest, you begin to walk along its length?
There are 4 options. I chose this one:
It would start moving in the opposite direction.
The book says it's the correct Answer, but I'm not quite sure why that is.
Is it because the Static friction coefficient is bigger than the force I exert on the skateboard by walking?
P.D. Would it be against the rules if I post a new question, about the same topic in this same thread, once I get the last one answered?
its not that its because action reaction.when you walk forward you exert a backward force on the skateboard which moves you forward and the backward force exerted by you moves the skateboard backward
Wow! Thanks, It seems a little more logical hehe :P
And it makes sense, since I'm studying Newton's 3 laws of motion. Thanks :)
welcome!if possible you can head for my question
You mean this question: "CHALLENGING pHYSICS questions(dedicated for lover's of physics)" 'Cause if so, I'm totally trying to solve that one, right after my Physics exam on Friday (Today :D )
It seems interesting, mainly because I'll have to read some old stuff, as well as some new stuff to even attempt to solve it.
Bye! See you around :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
