nicolas.1970
124 the first time (at office so not concentrated)
and 151 the second, which seems to be a little bit high :)
Armed with these insights (and two more right answers, of course) I retook the test and my score rose from 106 to 118. I was paying attention to things that didn't matter, like the positions of the little circles in the second one I posted. It seemed their placement had to be part of the pattern they were asking you to perceive but now I see some things can be ignored.Negatron said:Explanation:
The first one takes the first two in a row and performs a logical exclusive OR. So where blacks overlap, black is subtracted, where black exists in only one of the two elements, it is kept.
So D
The second one is set completion. Note that all squares have one empty dot on the outside, empty dot on the inside, and solid dot on the inside. The same for the circles. Naturally the same would be required for the triangles. A triangle with dot inside is the only one missing.
So B
Kurdt said:Probably E. The bottom left and then top right always rotate counter clockwise 90 degrees.
Chi Meson said:I agree, except for the "probably" part.
Kurdt said:The bottom left and then top right always rotate counter clockwise 90 degrees.
drizzle said:I think that I tend to complex the answer more than clarifying it, I wonder what use I can get of that way of thinking?![]()
zoobyshoe said:That fully qualifies you to engineer cars.
CRGreathouse said:Real IQ tests are mostly a joke. Fake IQ tests are entirely a joke.![]()
Chaos' lil bro Order said:
zoobyshoe said:...What's worse: a fast wrong answer or a slow wrong answer?
I think the "complex scoring algorithm" might explain how people can score as high as 90 with random choices: you're getting a lot more credit for fast right answers because the mechanism doesn't know they're accidental, but every wrong answer is simply wrong no matter how fast or slow.drizzle said:why bothering yourself, in the end they're both wrong![]()
zoobyshoe said:...I'm thinking if a fast right answer is better than a slow right answer, then a fast wrong answer should be worse than a slow wrong answer.
tribdog said:I'm really good at getting the wrong answer faster than most other people.
neu said:No, fulfill your dream of becoming an internet moderator.
