I want use plc program toI want Basthaddam 2 TON timers seemed
  • Thread starter Thread starter legendhollow
    Plc Program
The discussion focuses on using PLC programming to control Basthaddam 2 TON timers for a bulb's operation. The user seeks to configure the timers to run the bulb for 6 seconds instead of 4 seconds. Additionally, there is a requirement to run the bulb at the second and sixth seconds, with the second timer set to 4 seconds. The conversation includes references to attachments for further clarification. The goal is to achieve specific timing sequences in the PLC program for effective bulb control.
legendhollow
i want use plc program to
I want Basthaddam 2 TON timers seemed to run the bulb of 6 seconds and not run them at 4 seconds
2 - Run the bulb when the second and sixth run when second at 4 (means contrary to the above)
see the attachments
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
