akitokunx
- 2
AP Physics Momentum/Collision problem..
"A projectile of mass M is fired at an angle Theta (with the horizontal) from a cannon of mass 4M and velocity V on a friction-less flat surface. Determine Theta such that the distance from the end of the cannon (the hole of the cannon) to the projectile's peak is at a maximum. Hint: Let v = 1."
Answer: Theta = 50.49 degrees."
Theta, Mass, and Velocity are variables.
change in Y distance = V(initial)T - 1/2gt^2
Not sure if there are any other ones..
I drew this out with the cannon, on a frictionless flat surface, firing a projectile as such. Then, from there, after drawing out the Velocity vector on the mass, I attempted to break up my velocity vectors into the proper dimensional component:
where the velocity in the X = vcos(theta)
and velocity in the Y = vsin(theta)
from there I have no clue what to do. I've tried a couple of different things but I'm not sure how my teacher obtained a numerical value as the answer. He said to let V = 1 which I am clueless when to apply that.
Thank you very much for helping!
