- #71
gneill
Mentor
- 20,989
- 2,934
If the 3 Ohm resistance was not an intentional part of the original circuit then it is technically a short circuit.gracy said:If there is 4 ohm resistance in an intended or normal path of a circuit and there is an optional path where 3 ohm resistance is present.Then current will take route where there is 3 ohm resistance.Will it be called short circuit or greater difference in resistance is required?
If someone were to tell you to place a short circuit across the 4 Ohm path without any other details, then you would place zero Ohms (a wire) across it, because that is the conventional implication.
I can't provide a definition for "low" here. It depends on too many arbitrary or unspecified factors.
