B Idle Photons (motionless relative to the Earth's surface?)
A photon cannot be motionless relative to the Earth's surface, nor does it accelerate from 0 mps to 186,000 mps, as these concepts are rooted in classical physics rather than quantum mechanics. In special relativity, a photon is considered a massless particle that participates in interactions but does not conform to classical notions of motion. Quantum Electrodynamics defines the photon as a quantum of the electromagnetic field, where ideas of acceleration from rest do not apply. While photons in a vacuum maintain a constant speed, their behavior can change in different media, as demonstrated by experiments with Bose condensates. Overall, the discussion emphasizes the distinction between classical and quantum interpretations of photon behavior.
James William Hall
TL;DR Summary
Photon Motion
Can a photon ever be motionless relative to the earth's surface? Did it accelerate from 0 mps to 186,000 mps?
James William Hall said:
TL;DR Summary: Photon Motion
No* and no*.
*With relative velocity being defined through parallel transport along any arbitrary but given path rather than as a coordinate speed.
Likes Vanadium 50 and topsquark
This is really a Quantum Mechanics question. In SR the photon is simply a massless particle that may take part in particle collisions. But, the theory does not go any deeper that that and there is no theory on how the photon appears and no implication that it accelerates from rest.
In Quantum Electrodynamics, the photon is the quantum of the Electromagnetic field. It's not a point particle at all and a concept like "acceleration from rest" is a classical notion that has no place in the theory.
Likes topsquark and Dale
Note: my response in #2 was classical, basically interpreting "photon" to mean "pulse of light". @PeroK 's post #3 was quantum interpreting "photon" to actually mean "photon". So there will be some inconsistencies, just pick the answer that uses the meaning of "photon" that you intended.
Thank you both for your balanced explanations.
Photon in vacuum clearly cannot be stopped. If you Doppler shift it, its frequency changes... but you will find its speed unchanged.
How about photon in medium? Could you observe a photon in a medium such that the medium is moving relative to the observer/Earth surface in direction and with velocity opposite and equal to the speed of photon relative to the medium?
Lene Vestergaard Hau achieved some impressively big indices of refraction in media such as Bose condensate.
Also, photon cannot really "accelerate from rest". Indeed consider the basic limiting case of electromagnetic "waves" with zero frequency. On that limit, what we get is electrostatic and magnetostatic fields... which do not propagate, do not carry energy, momentum or angular momentum and are not quantized into real photons, only virtual ones. (Precisely how is electrostatic field expressed through the virtual photons, though?)
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
