If bar A moves right at a speed of x,how does bar B move?
  • Thread starter zizodev
  • Tags
    Speed
In summary, the bar B will slide to the right at a slower speed than bar A, with a speed of X/2. This is determined by the number of gears and their respective rotations based on the equation: speed of gear A * number of teeth A = speed of gear B * number of teeth B.
zizodev
Hi..
http://data.imagup.com/12/1146557882.jpg
speed of the gear(A) * number of teeth(A) =speed of the gear(B) * number of teeth(B)
as A slide to the right, so the C gear will turn Clockwise (CW);the D Anti CW ,E CW;
F anti CW so B will slide to the right.
about the spped the B will slide slower than rank A :)
thnks in advance.
hi zizodev! :wink:
yes, that's fine :smile:
quicker wold be to count the number of gears …
the are 4 circular gears, and 4 is even, so the first must go the opposite way to the fourth
(and yes, B will slide to the right, slower than A … you still need to count teeth to find how much slower! :wink:)
yes tiny-tim that's right...and the value is X/2 since the speed of the A=X.:)
yup! :smile:
Based on the image provided, it looks like bar B is connected to gears C, D, E, and F. Since bar A is moving to the right, the gears connected to it (C, D, E, and F) will also rotate in the same direction. This means that bar B will also move to the right, but at a slower speed than bar A. This is because the gears connected to bar B have different numbers of teeth than the gears connected to bar A, which will affect their rotational speeds. The equation you provided is correct and can be used to calculate the exact speed of bar B based on the speed of bar A and the number of teeth on the gears.
FAQ: If bar A moves right at a speed of x,how does bar B move?
How does the speed of bar A affect the movement of bar B?
The speed of bar A does not directly affect the movement of bar B. However, if bar A is connected to bar B through a mechanical system, the movement of bar A could cause bar B to move in a certain way.
Does the direction of bar A's movement determine the direction of bar B's movement?
Again, this depends on the mechanical system connecting bar A and bar B. If there is a direct connection, then yes, the direction of bar A's movement would determine the direction of bar B's movement. However, if there are other forces or factors involved, this may not be the case.
Can bar B move at a different speed than bar A?
Yes, it is possible for bar B to move at a different speed than bar A. This could be due to differences in the mechanical system connecting the two bars, external forces acting on bar B, or other factors.
What happens if bar A stops moving?
If bar A stops moving, it will depend on the mechanical system connecting bar A and bar B. Bar B may also stop moving, or it may continue to move in the same direction and at the same speed as before. Again, external forces or other factors may also play a role in the movement of bar B.
Is there a mathematical relationship between the speed of bar A and the movement of bar B?
In general, there is not a direct mathematical relationship between the speed of bar A and the movement of bar B. However, in some mechanical systems, there may be a specific equation or formula that describes the relationship between the two variables.
