If f+g is differentiable, then are f and g differentiable too?
  • Thread starter Thread starter samer88
    Differentiable
samer88
if f and g are two continuous functions and f+g is differentiable...are f and g differentiable? if not give a counter example!
I'm thinking not necessarily, but I'm not really sure. Whether a function is differentiable or not depends on whether on not every point on it has a derivative.
So say f is y = x^(1/3), and g is y = -x^(1/3). Both f and g are continuous - the graph of the function is unbroken.
(Technically the definition of continuity is that for every value in the domain the limit from below = limit from above = the value itself but yeah that's not really important.)
f+g is differentiate yeah? f + g just gives y = 0
However, y = x^(1/3) and y = -x^(1/3) are both non differentiable, since at the origin x = 0, the derivative is undefined. You get a divide by zero from memory =P
thnx clementc
haha no worries! =P
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
