If f is continuous at c and f(c)>1
  • Thread starter Thread starter H2Pendragon
    Continuous
H2Pendragon
Hi everyone, this is probably an easy question but I'm having trouble on the wording of the proof.
Let f be continuous at x=c and f(c) > 1
Show that there exists an r > 0 such that \forall x \in B(c,r) \bigcap D : f(x) > 1
\forall \epsilon > 0, \exists r > 0, \forall x \in B(c,r) \bigcap D \Rightarrow |f(x) - f(c)| < \epsilon
f(c) > 1
I'd put something here but I don't really have any attempts. I originally thought of using the limit rule that lim f(x) = f(c) but that doesn't work since c could be an isolated point.
If I used a graph it just seems so obvious, but I have to use words to prove it. I tried also to use a contradiction, but using just what I put down in (2) didn't lead to any direct contradiction that I could see.
A nudge in the right direction would be helpful.
If in doubt try an example.
Let's say for the sake of argument that f(c)=2. What choice of epsilon, and r, from 2. above will mean that f(x) > 1 in the ball around c?
-e<f(x)-f(c)<e
f(x)>f(c)-e
f(c)=1+h^2 for some h real, do you understand how to pick e such that f(x)>1.
MathematicalPhysicist said:
-e<f(x)-f(c)<e
f(x)>f(c)-e
by this reasoning couldn't I just claim that f(c) = 1 + e?
Yes, you can do that.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
