Squizzie
- 155
- 11
- TL;DR Summary
- Why, if the source of the pressure distribution around a lifting airfoil is known, is it not explained in any textbook?
This question presupposes that textbooks do not explain the source of the pressure differences around a lifting airfoil, so the first challenge would be to demonstrate that it is in fact the case that an explanation is not to be found. I think I can present convincing evidence that it isn't.
Philosophically, it is impossible to prove a negative, so I will turn to one of the most recognised authorities, Anderson, J. D. (2011) "Fundamentals of Aerodynamics" Fifth Edition. An on-line version can be borrowed from archiv.org at Fundamentals of aerodynamics : Anderson, John D., Jr. (John David),
On p. 282 he states:
"Keep in mind that the true physical sources of aerodynamic force on a body are the pressure and shear stress distributions exerted on the surface of the body, as explained in Section 1.5. "
And in the references section 1.5, on p. 18:
" However, in these and all other cases, the aerodynamic forces and moments on the body are due to only two basic sources:
1. Pressure distribution over the body surface
2. Shear stress distribution over the body surface
No matter how complex the body shape may be, the aerodynamic forces and moments on the body are due entirely to the above two basic sources. The only mechanisms nature has for communicating a force to a body moving through a fluid are pressure and shear stress distributions on the body surface. "
However, there no explanation is provided in Section 1.5 for the pressure differences.
An exhaustive search of the aerodynamics literature, including Lanchester (1907), Prandtl (1922), Pope (1947), Clancy (1975), Bertin (2009), Mclean (2013), Drela (2014) has similarly revealed no explanation for the pressure differences.
So my question is, why isn't the pressure distribution around a lifting airfoil explained in the literature?
