If water molecules are so smallwhy don't they go through skin pores?
In summary: The Transdermal Delivery Systems delivery a drug directly into the bloodstream-avoid liver metabolism-result in less side effects
Mintaka
I read that essential oils can go through the skin. I am told that there are more water molecules in just 10 drops of water than stars in the whole universe, so if they are so tiny, why don't they go through the skin membrane pores, which are perfectly visible under an optical microscope? You would think they would flood through.
Thank you
Why do you think they don't?
Have you ever heard of a wine skin?
The old-old style was made from the skin of a domestic animal.
The water does not flood through so to speak, so there must be a reason why not.
Can you think of a reason, or a couple of them, why not.
Goretex is designed to let molecules of water through but the membrane is still impressively 'waterproof'. It could be easier, perhaps, to think in terms of a simple artificial structure rather than a biological one. Your skin pores are not just holes in the skin.
I see I have been showing my ignorance here. I suppose my question should have been : "Why do some medicines, poisons and pharmacceutical chemicals pass through into the bloodstream, but water molecules do not" ?
Thank you
I believe that you will find that perspiration involves the passage of water molecules through the skin. I also think that you will find that skin pores are not simply openings in the skin, but are functioning portals that both permit and bar passage of both gases and fluids. The default position is closed, hence the past use of "wine skins".
I really appreciate your answers, but still no answer as to why chemicals like nicotine can pass into the bloodstream but water doesn't.
Why do you keep insisting that water cannot pass through the skin? Have you not seen what happens when you spend a long time laying in a bath of fresh water? The skin of your fingers becomes noticeably puffy because of osmosis. The same happens to all of your skin but it is not so visible although the skin feels different. Because the rate of diffusion depends upon the relative concentrations of molecules on either side, it is not surprising that the rate of passage of water is slow - you already have most of your tissue full of water.
Thanks for your reply, I understand that my skin is soaked and puffy, but the water (and soap too presumably) don't pass into the bloodstream, do they?
But nicotine isn't entering the bloodstream via your skin pores
Its entering via processes occurring primarily in the lungs
You may also consider that because blood plasma is >90% water
there are obviously processes occurring in the body that allow water to
enter and make up a large % of your blood streamDave
Likes 1 person
How do you 'know' that none of your bathwater gets into your bloodstream? How would you ever have been able to do a test for it? If it gets into your skin, why wouldn't you expect it to get as far as your blood stream? Having established that large molecules like Nicotine get through your skin and the bathwater effect, how can you still believe that water doesn't get into your blood stream. What would you think would be the effect of a few grams of water getting in through your skin? Is it likely to cause any detectable reaction? Otoh, a gram of Nicotine would kill you (or a picogram of a nerve gas, probably!)
Dave
If you are "trying to give 'em up", you use skin patches.
Likes 1 person
true, like my pain killer morphine patches
Im assuming its an osmosis function occurring here ?
... wanders off to google to find out :wink:
Dave
Likes 1 person
OK from ...
http://www.transdermalspecialties.com/technology.html
Technology
Transdermal systems deliver drugs through the skin into the bloodstream. Medications delivered via skin patches avoid liver metabolism, a necessary feature for drug molecules to metabolize easily, and allows for lower dosing of medications. There are two types of transdermal delivery systems:
Passive – In passive transdermal systems, the drug diffuses through the skin via the process of osmosis where it can act locally or penetrate the capillaries for systemic effect. This technology is only effective with small molecule drugs such as in nicotine patches i.e. nicotine has a molecular weight of 162 Daltons versus 5,808 for insulin.
•Active – In active transdermal systems, a physical force is used to facilitate the movement of drug molecules through the skin. By using an applied force (such as ultrasound), active transdermal systems are capable of delivering proteins and other large molecule formulations through the skin and into the blood stream at a speed unmatched by invasive systems such as micro needles and insulin pumps.
cheers
Dave
it's fascinating :-) You are saying that soap and water can actually get into my bloodstream when I'm having a bath...:-) It's a strange thought...))) I was led to believe the skin is like goretex, allows sweating out but no way in...))) You guys are brilliant, thank you...
Goretex works in either direction but the majority of the water will go from the more concentrated region to the less concentrated region (normal rules of diffusion). Larger molecules will probably not pass through goretex. Because the 'holes' in your skin are not just simple geometric shapes (there will be a pattern of charges around them) there will probably be a certain amount of selectivity which is more than just dependent on the physical size of the molecule trying to get in.
Edit: On the subject of goretex membrane, there were a number of goretex tents on sale about ten (?) years ago. They then ceased to appear in the shops. I asked a guy in an outdoor shop about that and he said they didn't work very well because "you need a difference in climate between inside and outside". I presume he meant a difference in temperature on the inner and outer surfaces - to raise the vapour pressure slightly on the outside. In a tent. the air next to the internal skin of the tent is likely to be cooler than in clothing - nearer the body.
Likes 1 person
Related to If water molecules are so smallwhy don't they go through skin pores?
1. Why don't water molecules go through skin pores?
Water molecules are small, but they are still larger than the pores in our skin. The pores in our skin are made up of tiny openings called dermal pores, which are small enough to prevent most substances, including water molecules, from passing through.
2. Can water molecules pass through other substances, such as clothing or plastic?
Yes, depending on the material and its density, water molecules can pass through other substances. For example, some types of clothing, like cotton, are more porous and allow water molecules to pass through, while others, like plastic, are more tightly packed and prevent water molecules from passing through.
3. Do water molecules ever pass through our skin?
While water molecules cannot pass through the dermal pores in our skin, they can be absorbed into the skin through a process called osmosis. This occurs when there is a difference in concentration between the water inside and outside of our skin cells, causing the water to move into the cells.
4. Are there any substances that can pass through skin pores?
Yes, while most substances cannot pass through the dermal pores in our skin, there are some substances that are small enough to do so. This includes gases, such as oxygen and carbon dioxide, as well as some medications and chemicals that are specifically designed to be absorbed through the skin.
5. Can water molecules cause any damage to our skin?
Water molecules are essential for our skin's health and hydration, but in certain situations, they can cause damage. If our skin is exposed to water for long periods of time, it can lead to skin wrinkling and softening, which can make it easier for substances to pass through the skin. Additionally, if the water is contaminated with harmful substances, it can cause irritation and damage to our skin.
  • DIY Projects
9K
  • Mechanical Engineering
