I'm in need of help on my physics
  • Thread starter cmwestbr
  • Tags
    Physics
In summary, the conversation is discussing how to calculate the net gravitational force acting on three particles located on a straight line. The masses of the particles are 363 kg, 517 kg, and 154 kg, and the direction to the right is considered positive. The conversation also mentions treating objects as uniform spheres and using the equation G*m1*m2/r^2 to calculate the maximum gravitational force between two objects.
cmwestbr
Could anyone help me with these problems? It's on Gravitational Force
The drawing shows three particles far away from any other objects and located on a straight line. The masses of these particles are mA = 363 kg, mB = 517 kg, and mC = 154 kg. Find the magnitude and direction of the net gravitational force acting on each of the three particles (let the direction to the right be positive).
particle A N
particle B N
particle C N
A bowling ball (mass = 7.2 kg, radius = 0.10 m) and a billiard ball (mass = 0.32 kg, radius = 0.028 m) may each be treated as uniform spheres. What is the magnitude of the maximum gravitational force that each can exert on the other?
particle A N
particle B N
particle C N
The fact that the 3 masses are far away from any other object imples that only the 3 masses are interacting with each other via the gravitational force. You can treat them as uniform spheres, which means that they are point particles located at the sphere's center with mass M. So, what is the equation that you are going to use ?
marlon
Start from the basic and use this for a system of two particles separated by distance r.
use... G*m1*m2/r^2
Now see that 3 particles can create 3 pairs.Be careful with the distance between a and c and the sign notation when moving from c to a and from b to a.
so what ima do is...6.67*10^-11(363kg)(517kg)/9.8^2...or is that not right?
FAQ: I'm in need of help on my physics
What specific topic in physics do you need help with?
Physics is a broad subject, so it would be helpful to know which specific topic you are struggling with. This will allow me to provide more targeted assistance.
Can you explain the concept in a simpler way?
Sometimes, complex physics concepts can be difficult to understand. I will do my best to break down the topic into simpler terms and provide real-life examples to help you better understand it.
How can I apply this concept to real-life situations?
Many students struggle with understanding how physics applies to their everyday lives. I will try to provide practical applications of the concept you are struggling with to help you see its relevance.
What equations or formulas should I memorize?
In physics, there are many equations and formulas that are important to know. I can help you identify which ones are most commonly used and provide tips on how to memorize them effectively.
Can you recommend any additional resources for further help?
Aside from our sessions, there are many other resources available to help you with your physics studies. I can recommend textbooks, online tutorials, and practice problems to supplement your learning and improve your understanding of the subject.
