Impact of AC effects on current density analysis of pcb for 50-60Hz
Current density analysis for PCBs handling 50-60Hz AC power shows minimal deviation from DC characteristics due to the larger skin depth compared to trace dimensions. For typical PCB designs, AC effects can often be ignored, especially with wider traces that reduce inductance. However, considerations must be made for sufficient copper thickness to handle the required current and to prevent insulation breakdown between tracks. The discussion also highlights the importance of adhering to safety agency design rules when distributing AC mains power on PCBs. Overall, while AC impedance analysis is crucial for high-frequency circuits, it is less critical for low-frequency applications like 50-60Hz.
ursonor99
TL;DR Summary
what is the correct approach to current density analysis of a PCB when it is distributing 50-60 hz AC power
Hello ,
I was looking into current density analysis of a PCB that handles distribution of AC power . from ansys and cadence sites , i realized by current density they refer to DC IR drop that is a pure ohmic analysis that doesn't take into consideration the AC effects . And in order to take this into consideration , we need to go to AC impedance analysis and obtain EM losses . But I observed this kind of analysis was done for high frequency AC circuits for decoupling cap suggestions etc .
So i was curious to know how much the current density behavior will deviate from DC for a low frequency like 50-60Hz ? as for such frequencies the skin depths are much greater than trace width and thickness
Welcome to PF.
Your instincts are good; 50-60Hz AC should not deviate much from DC for reasonable size PCBs. Is this for a power supply PCBA? Why are you needing to distribute AC Mains frequencies on a PCB? What kind of currents and voltages are involved? Are you well-versed in safety agency AC Mains design rules?
Welcome to PF.
The voltages are 208VAC 4W . the pcb takes AC mains power and generates few DC voltages and also powers few AC motors etc .
The traces on a circuit board are thin compared to skin depth in copper at 50/60 Hz. For that reason AC effects can be ignored. The tracks will be wide, so will have lower inductance. Avoid multi-layers as I²R heat needs to escape.
One problem will be having enough copper section to carry the required current.
Another problem will be surface insulation breakdown between tracks or surface terminals, that may require slots be cut in the PCB.
With my Mentor superpowers, I can see what country you are posting from. What safety agency approvals will you be applying for with this new product?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
