I Importance of Moment of Inertia for designing helicopters and propellers?
  • I
  • Thread starter Thread starter OnlyPhysics
    Academic Book
The discussion emphasizes the significance of moment of inertia in helicopter and propeller design, particularly regarding rotor blade deformation under load. It highlights that material stiffness and geometric design are crucial for minimizing deformation, as fixed material constraints can limit options. The moment of inertia affects the lift produced by the blades, which can lead to discrepancies between calculated and actual lift if deformation is not accounted for. Recommendations for further reading include "Mechanics of Materials" by Barry J. Goodno and James M. Gere for foundational concepts. The complexity of blade geometry suggests that advanced analysis may require computational fluid dynamics (CFD) and finite element methods (FEM).
OnlyPhysics
is there any book or academic web page "that explains that importance of moment of inertia for designing helicopter and propeller". Actually i have idea why it is important i just need a reference.
It might be something to do with the circular motion of the rotor blades?
There isn't much context to work with from the OP. I assume the moment of inertia it is talking about is for the cross-section of the blades which relates to how it deforms under load.
The material stiffness also affects how it deforms but geometrical solutions have a lot of potential to reduce the deformation while changing the material only affects it linearly. Besides, sometimes materials are already fixed because of other constraints such as oxidation, temperature resistance, price, manufacturability, availability, etc.
Lift produced by the blades will deform them and if the moment of inertia (and the material stiffness is not chosen to compensate) it could result in the blade having a significantly different profile than the one initially studied for the undeformed geometry. Therefore, the calculated lift will differ from the actual lift that it will produce if the deformation is not considered and it's big enough to have an impact.
Also, in the dynamic case, if the blades are too wobbly all kinds of bad things can happen to it.
Regarding the book @OnlyPhysics was asking for, if the post is related to what I'm saying I'd recommend any book about Mechanics of Materials that talks about beams for a conceptual understanding of the matter. For example, Mechanics of Materials by Barry J. Goodno and James M. Gere.
For a more focused analysis of that particular problem, I don't know any book though. Since the profile of the blade is constantly changing along its length and its geometry is fairly complex I'd assume it must be solved with a combination of CFD and FEM.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
