Improving Resolution of Sensor Output
The discussion focuses on improving the resolution of a sensor output signal conditioning circuit, which currently has a limited DC output range of 2.467V to 2.561V. The user seeks to amplify small AC voltage changes (2mV-5mV) and translate the output to a 0V to 5V range. Suggestions include using a series capacitor to block DC bias and employing an inverting amplifier for gain, while cautioning that this could distort the signal. The demodulator's role in processing the sensor's modulated output at 100 kHz is also highlighted, with recommendations for adjusting the amplification sequence to enhance output clarity. Overall, the conversation emphasizes the importance of understanding signal processing fundamentals to achieve the desired output.
akhurash
I'm working on a sensor signal conditioning circuit. The sensor output has a 2.5V DC bias with a peak-to-peak voltage swing of about 50mV. The signal output is put through a demodulator and then filter (LPF) to obtain a DC voltage proportional to the out of the sensor. The problem is I need to be able to sense very small changes in the AC voltage output from the sensor (~ 2mv-5mV peak-to-peak changes). I'm new to signal conditioning and processing sensor outputs so I was wondering if anyone here knows how I can do this. I want ot learn about the basics and theory behind how to amplify the signal.
Currently my DC output goes from about 2.467V to 2.561V (with the midpoint being about 2.514V, the DV bias). I need to translate that into a DC voltage swing of 0V to 5V, or something better than 2.467V to 2.561V.
The way I'm thinking about doing this gaining the AC voltage BEFORE the LPF. I'm currently trying this approach but it isn't working because my output signal is all distorted after the AC gain.
You can use a series capacitor to block the DC bias on the signal. If you didn't mind a positive/negative signal you could then just use an inverting amplifier with a gain of say 100 to get you to a +/- 5V signal.
You should be able to just google series capacitor and inverting amplifier to learn more about them.
You didn't say what frequency range you are interested in, except for mentioning the LPF.
A simple "blocking capacitor" circuit to get rid of the DC is really acting as a HIGH pass filter, so you would need to be sure it wasn't affecting the low-frequency content of the signal that you want to keep.
You mentioned a demodulator as the first step in the signal processing chain, but didn't say anything about what it was for. Maybe you would be better to shift the signal level by about 2.5V (e.g. with a DC coupled unity gain amplifier) before the demodulator, and do the 100x amplification last, after the demodulation and LPF? But that's guessing, without knowing more about the demodulation step.
Thanks for the replies. I kind of gave the wrong impression when posting this. I actually want to amplify/scale the DC range of 2.467V to 2.561V to make that range go from 0V to 5V with 2.5V being the mid voltage. Since the voltage is almost pure DC after the LPF (I have three, one active 2nd order and two passive) I can't block the DC, that is my information.
The demodulator is used to process the output signal of the sensor (which is modulated with a carieer frequency of 100 kHZ). My LPF's have a cutoff frequency of 10kHZ because my sensor output information is contained within the DC voltages after the demodulator.
Here's a simple circuit that could be a starting point. Note that the final opamp must have rail to rail capability and a high enough slew rate to handle your signal.
Here is a fairly standard opamp circuit:
http://dl.dropbox.com/u/4222062/opamp%20non%20inv.PNG
It uses a precision opamp but almost any type would be OK. If you wanted the output to go to zero volts with a single supply, then you would pick an opamp which could do this.
The voltage source V1 would be removed and your input would be brought in here.
Capacitor C2 is optional. It wasn't necessary for the simulation, but may be advisable in practice if the wire lengths were significant.
One of the resistors shown as R2 and R3 would probably be made variable. Or you could replace both of them with a multi-turn pot.
You could increase the gain by increasing the resistance of R1. As shown, the gain is about 19.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
