Impulse and momentum of two particles
The discussion centers on calculating the impulse exerted on particle A during a collision. Particle A, initially moving at 3 m/s, slows to 1.2 m/s after the collision, leading to a calculated impulse of -0.216 Ns. The negative sign indicates that the impulse acts in the opposite direction to A's initial motion, reflecting a decrease in speed. Participants clarify that the magnitude of impulse is simply the absolute value, which is 0.216 Ns. Understanding the negative impulse helps illustrate the direction of the average force acting on particle A during the collision.
Pagey
Two particles have mass 0.12kg and 0.08kg respectively. They are intially at rest on a smooth horizontal table. Particle A is then given an impulse in the direction AB so that it moves with speed 3m/s directly towards B.
Immediately after the particles collide the speed of A is 1.2m/s, its direction of motion being unchanged.
(c) find the magnitude of the impulse exerted on A in the collision.
impulse = change in momentum (mv-mu)
(c)
I get
impulse = mv-mu
= (0.12 x 1.2) - (0.12 x 3)
= - 0.216 Ns
But the mark scheme said the answer is + 0.216 Ns ... how can this be if the velocity after is less than the velocity before, i don't understand why??
Hi Pagey,
They asked for the magnitude of the impulse so they just need the absolute value.
O so the maths is right. Ok it makes sense now, cheers!
What is a negaitve impulse then, what does the - 0.216 mean? why is the answer negative (ingorning the fact it asks for magnitude)?
B consumed that momentum.
The negative sign in the impulse indicates direction. The direction of the impulse is the same direction as the average net force during the collision.
So you called the velocities of particle A positive (they are both in the same direction in this problem). That set your coordinate system so that postive direction is in the direction of the velocities of A. But if A is slowing down, which direction is the average force on it? It is in the opposite direction of the velocities, and so since you already called the velocites positive, the average force and therefore the momentum must be negative.
(If particle A was moving to the right, then it needs a force to the left to slow it down.)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
