Impulse Engine (Drive) ....a stupid question?
The discussion revolves around the concept of using centripetal force in space to generate movement by swinging a rock attached to a rope. It explores the implications of Newton's second law, suggesting that upon releasing the rock, the individual would move in the opposite direction, resulting in no net change in position. The conversation then shifts to whether similar principles could apply at the quantum level, particularly with electrons and magnetic fields. Ultimately, it concludes that while energy can facilitate movement, it does not result in a permanent change in velocity or position in the rest frame. The realization highlights the limitations of this method for achieving significant movement.
infinitrode
Recently, I've been watching a lot of those youtube videos debunking gyroscopic propulsion because everything about it violates the second law of motion or something...
This got me thinking, if I was floating in space and I decided to swing a large rock on a rope around me, to generate some centripetal force on the rock, then let go of the rope (it's a really long rope and I'm attached to the slack), I'm assuming it would just float away from me given the centripetal force. Now, since I'm attached to the rope, and given Newton's second law, I would be able to pull my self a significant distance given the mass and velocity of the rock. Correct?
Assuming this is correct, would something similar to this effect be possible on the quantum level with electrons and magnetic fields or something?
Science news on Phys.org
You move some distance, to rock moves in the opposite direction. At some point the rope does not allow more motion, you and the rock are stopped (in the frame of your original position) and you end up with exactly the same speed as before. Yes you moved a bit, but the rock did that as well, if you pull it back you end up in the same position as you started.
You can move around everything with energy, but I don't see the point. You cannot change your velocity, and you cannot even permanently change your position (in your rest frame) by a relevant amount.
Dang it, you're right. My first thought was that the amount of energy expended in generating a large centripetal force should transfer to distance gained when I pull on the rope after I let it go, but instead, after you let it go, you traveled in the opposite direction at a proportional speed. Thanks.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
