- #281
waynexk8
- 398
- 1
DaleSpam said:I have a PhD in biomedical engineering and did some coursework and research in functional electrical stimulation for neuro-prosthetic applications, so I know a thing or two about EMG, EEG, EKG, muscle recruitment, electrical stimulation, pacemakers, etc.
Wow, great. And that’s meant as a complement, as I am glad you also know about EMG.
DaleSpam said:Electrical muscle activity measures voltage changes due to the depolarization of the muscle cell membranes during the muscle's action potential, not the force exerted by the muscle.
Note, the key word "estimate". If you know the EMG and you know the tension v recruitment curve and you know the position of the limb and you know the force v tension curve for that position then you can use the EMG to make a good estimate as to what the force is. An estimate and a measurement are not the same thing. Force is measured with a force transducer, an EMG is a voltage transducer. The units of the EMG are μV, not N.
Before you can prove your total/overall muscle force theory you need to define it, otherwise there is no theory to prove or disprove. That is the purpose of teaching you about the standard physics concepts. I am hoping that as you learn what is meant by them you can express your concepts in the standard language, clearly define your theory, and then we can see the implications.
I have not the time tonight to give you a well deserved answer for the above, so will come back to this tomorrow.
DaleSpam said:So, let's talk a little more about impulse and see if it has the properties that you expect for "total/overall muscle force".
Impulse also has the property that if you exert the same force for twice as long you have doubled your impulse. So, for example if you exert 100 lbs for 10 s and I exert 100 lbs for 5 s you have exerted twice the impulse that I have. Does this also agree with your concept of "total/overall muscle force"?
As you know answered this in my last post.
Either we are all cross threaded, because I as I said, don’t get that when I say I am trying to use 100% strength for 6 seconds or 30 seconds, on a weight that is 80% of my 1RM {repetition maximum} and then you say you are only going to use 80% strength for 6 seconds or 30 seconds, on a weight that is 80% of your 1RM {repetition maximum} that you or some of the other here, turn around and say 80% strength/force is equal to 100% strength/force ?
And there is more than enough proof and evidence, as the 100% strength using person fails roughly 50% faster. So as I asked before,
1,
I fail at 30 seconds; you fail at 60 seconds, who puts the most tension on the muscles.
2,
I fail at 30 seconds, lift a lighter weight and fail at 30 seconds again; you fail at 60 seconds, who puts the most tension on the muscles.
3,
I lift for 30 seconds, and you lift for 30 seconds.
All can’t use the same force and have the same tension on the muscles.
Wayne
