In order to generate electricity is copper required?
In summary, copper is commonly used as a conductor in generators due to its low cost and high conductivity. Silver is more conductive, but its high cost and weight make it less practical. Graphene, a new material, may have potential for use in generators in the future. The choice of conductor is a compromise between cost, strength, resistance, and other factors. During WWII, silver was temporarily used as a substitute for copper in the Manhattan Project, highlighting the importance of copper in electrical applications.
dan020350
35
Copper conducts electricity and so does other metals like silver. Now a new material is coming to play which is graphene, But I was wondering in order to generate electricity must it be in copper coils? Can it be in silver coils, graphene coils?
There's no need for copper to be involved. Any conductor will do in a generator. The reason copper is used is that it's cheap and quite conductive. Silver is a little bit more conductive, but it's much more expensive as well as heavier.
So a silver coils can generate electricity better then copper. What would be the best metal?
There is a lot of vibration in a generator. You don't want to use a material for the coils that is any more brittle, or that could compromise the generator's reliability.
I don't know how silver compares.
This is an engineering matter and it's all based on compromise. The almost universal choice of a material indicates that it is suitable in more than just one respect - not too expensive, almost strong enough, low enough resistance, fairly corrosion free etc. etc. In fact, high purity copper is not used for all cables. It is just not strong enough to support its own weight for overhead HV cables, for instance. For a while, when copper prices were exceptionally high, aluminium was used for domestic wiring (and stainless steel for plumbing).
Copper does corrode a bit on its surface, which is why PC board and other connectors are plated with more expensive metals (gold, rhodium etc.).
Graphene may well be used for many applications in the future. T present, it is a lot less convenient at the moment, for everyday use, I think. Copper may increase in price and things may change sooner than you think.
Any conductor will do. As a matter of fact, the high voltage power transmission lines that one sees hanging from the tall towers are made of aluminum, not copper--aluminum being lighter and cheaper than copper.
The conductivity and resistivity of silver and copper are almost identical, but the price of silver is currently more than 100 times that of copper.
During WWII, copper was in extremely short supply in the US in 1942. The Manhattan Project, which was charged with building the first atomic bomb, desperately needed a large amount of copper to fabricate electromagnets which were used to separate uranium isotopes. When no source of copper could be readily found, the US Army approached the Treasury about borrowing some of its silver stockpile, to be used instead of copper. The Treasury secretary reluctantly agreed, and eventually more than 14,000 tons of silver were put to work in electromagnets for the duration. The last of the silver was returned to the Treasury eventually in 1970, after the equipment which used it was dismantled.
http://en.wikipedia.org/wiki/Manhattan_Project
FAQ: In order to generate electricity is copper required?
1. What is the role of copper in generating electricity?
Copper is a highly conductive metal that is used in electrical wiring and components to carry and transfer electricity. It is essential for the efficient transmission and distribution of electricity in power grids.
2. How is copper used in power plants to generate electricity?
In power plants, copper is used in the form of wires, coils, and other components to create electromagnets that are used in generators. These generators convert mechanical energy into electrical energy, and copper plays a crucial role in this process.
3. Is copper the only metal used in electricity generation?
No, copper is not the only metal used in electricity generation. Other metals such as aluminum, silver, and gold are also used, but copper is the most commonly used due to its high conductivity and relatively low cost.
4. What are the benefits of using copper in electricity generation?
Copper is a highly efficient conductor of electricity, which means it can transfer electricity with minimal loss of energy. It is also a durable and corrosion-resistant metal, making it a reliable choice for long-term use in power generation.
5. Are there any alternatives to using copper in electricity generation?
While copper is the most commonly used metal in electricity generation, there are alternatives such as aluminum and superconductors. However, these alternatives may not be as cost-effective or efficient as copper in certain applications.
13K
