NTL2009
- 637
- 393
I'm certain these must be common in automotive applications, but I'm just not sure what search terms to use.
I'm looking for an on/off switch (to be electronically sensed, so low volt/current) that can be connected to a water pipe, and turn on/off at around 1~2 PSI.
The specific application is to monitor (with an Arduino-based NodeMCU) how often and how long my sump pump runs. Since it has to pump the water up ~ 10', the pressure in the discharge pipe (even w/o any added pressure from flow resistance) would be over 4 PSI. The discharge pipe is common 1 1/2" PVC, easy to drill/tap.
My first attempt was with one electrode in the pipe, just below the check valve, and another in the water at the bottom of the pit. But the check valve keeps the water trapped in that pipe, even with a 'weep hole' at the bottom (like putting your thumb on a straw).
I bought some AC current sensing modules, but I have to break into the line, or the cord to use them. There's not enough room in the box, and I don't really want to cut up the cord to isolate one line (void the warranty), so that gets a little messy (but do-able if needed).
I have three pumps in the pit, (1) a battery backed up one, (2) the (formerly) 'main' 1/2 HP pump, and I added a 3rd, cheap 1/6th HP pump that should be able to handle normal conditions, and save wear/tear on the 1/2 HP pump (which runs for only 5 ~ 7 seconds per cycle, and the integrated float is not adjustable). So a simple, common solution for all three would be preferred.
In the mean time, since my 1/6th HP pump uses an external float/Switch, I can put a multi-tap on that with a USB power tap to feed the input of the Arduino, that's a partial solution.
TIA - NTL2009
TIA - NTL2009
