In what unit do you measure potential energy?
Potential energy and kinetic energy are both measured in joules (J), which is the standard unit of energy. The relationship between force, mass, and acceleration illustrates how units are derived, with force being expressed as kg·m/s², known as a Newton. Energy remains constant in a closed system, where potential energy converts to kinetic energy and vice versa, but the total energy does not change. Therefore, all forms of energy, including potential and kinetic, share the same unit of measurement. Understanding these concepts is essential for grasping the principles of energy conservation.
RMHAZARD
HI WHAT UNITS DO U MEASURE pOTENIAL ENERGY AND KINETIC Energy in please
What grade are you in?
You answered this question yourself in your "help " thread
A really cool thing about units: If you know a formula for something, then you know the units, in a way. For example, you know that
Force = Mass x Acceleration
If the units of Mass are kg and the units of acceleration are m/s^2, then the units of force are kg x m/s^2. Force is an important concept, and so we have a special name for it: Newton. Still, kg x m/s^2 is also correct, although you may lose points for using it.
A really cool thing about energy: Imagine a bottle with a wind-up toy in it, so well sealed and isolated that nothing could get in or go out. No matter, no energy, nothing. The total energy in the bottle: kinetic + potential + whatever will never change. At first, there's a lot of potential energy in the wind-up toy's spring, but little kinetic energy, because the car is still. Later, the spring winds down, and there is little potential energy, but plenty of kinetic energy, because the car is moving. The sum of the energy doesn't change though. Think about it. You can add up the different forms of energy. That means that they have the same units. No special units for kinetic energy, potential energy, whatever energy. Just one unit for all kinds of energy...
Hope this helps...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
