Incline plane, two masses, a pulley
The discussion revolves around a physics problem involving two masses connected by a string over an ideal pulley, with one mass on an inclined plane and the other hanging. The goal is to determine the angle theta that allows the mass on the incline to move at a constant speed. The user sets up the equations of motion for both masses, considering forces such as gravity, tension, and friction. They express uncertainty about the direction of movement and whether their setup is correct, ultimately leading to a derived equation involving theta and the coefficient of friction. The user concludes that they believe they have correctly set up the problem but are struggling to solve for theta.
jimz
A string through an ideal pulley connects two blocks, one (mass=2m) is on an inclined plane with angle theta to horizontal and coefficient of kinetic friction mu. The other block (mass=m) hangs off the pulley on the high side of the inclined plane.
(looks like this, except no acceleration and the block on the plane is twice the mass of the hanging block:
http://session.masteringphysics.com/problemAsset/1010976/24/MLD_2l_2_v2_2_a.jpg)
Find the angle theta that allows the mass to move at a constant speed.
First, I'm not even sure which direction the blocks will move, and I'm not going to figure it out but I suspect they can move at a constant velocity either way if we vary theta and mu. For now I'll assume that the 2m mass will move down the plane towards the earth. If that's wrong a the friction sign will be changed but the same idea here.
for the 2m mass, with +x along the plane pointing down, and y perpendicular pointing up :
\sum F_{2mx}=F_{gravityx}-F_{frictionx}-T
\sum F_{2mx}=2mg sin \theta-(\mu)(2mg cos \theta)-T
\sum F_{2my}=N-F_{gravityy}
\sum F_{2my}=N-2mg cos \theta
for the m mass, with +y in the up direction:
\sum F_{my}= T-F_{gravity}
\sum F_{my}= T-mg
At a constant velocity, neither block is accelerating, so a=0
I believe all I need to do is focus on one mass, I'll try block on the plane (mass=2m) with the x direction along the inclined plane.
\sum F_{2mx}=2mg sin \theta-(\mu)(2mg cos \theta)-T=2m\ddot{x}=0
Can I then assume T=mg from the hanging mass with no acceleration?
2mg sin \theta-(\mu)(2mg cos \theta)-mg=2m\ddot{x}=0
mg(2sin \theta-(\mu)(2cos \theta)-1)=0
sin \theta-(\mu)(cos \theta)-\frac{1}{2}=0
-(\mu)(cos \theta)=\frac{1}{2}-sin \thetaAnd then I'm kind of stuck and unsure I even set it up right.
Thanks!
Is this your homework?
yes, it's a problem from our book. Does that matter?
I now think I set it up correctly and it's now just a math problem but I still can't get anywhere closer to the solution for theta.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
