Inclined plane - a small sphere, a big sphere and a cylinder
In summary, the conversation discusses the rolling of solids on a plane with no resistance. The net torque, moments of inertia, and angular acceleration are calculated for a cylinder and two spheres, leading to the conclusion that the small sphere will roll out of the plane first. However, there is a discrepancy in the calculation of the torque and it is suggested to use energy conservation or consider the force of static friction on each object. Ultimately, the final attempt simplifies the linear acceleration for the cylinder, but it is noted that the coefficient of static friction may not be relevant in this scenario.
ChessEnthusiast
115
We place a cylinder with radius R, a sphere with radius R and a sphere with radius (2R). Which of the solids will roll out of the plane first? Assume no rolling resistance and no air resistance.
1) The net torque is the torque of the force of static friction.
[tex]M_{bigSphere} = fm_{1}g\cos(\theta)[/tex]
[tex]M_{smallSphere} = fm_{2}g\cos(\theta)[/tex]
[tex]M_{cylinder} = fm_{3}g\cos(\theta)[/tex]
2) The moments of inertia:
[tex]I_{bigSphere} = \frac{2}{5}m_{1}(4R^2)[/tex]
[tex]I_{smallSphere} = \frac{2}{5}m_{2}R^2[/tex]
[tex]I_{cylinder} = \frac{1}{2}m_{3}R^2[/tex]
1) I calculate the angular acceleration for each of the solids:
[tex]\epsilon_{bigSphere} = \frac{fm_{1}g\cos(\theta)}{\frac{2}{5}m_{1}(4R^2)} = \frac{5gf\cos(\theta)}{8R^2} [/tex]
[tex]\epsilon_{smallSphere} = \frac{ fm_{2}g\cos(\theta)}{\frac{2}{5}m_{2}R^2} = \frac{5gf\cos(\theta)}{2R^2}[/tex]
[tex]\epsilon_{cylinder} = \frac{2fg\cos(\theta)}{R^2}[/tex]
Since the small sphere has the biggest angular acceleration, it will take it the least time to roll out of the plane.
Is my solution to this problem valid?
Does a small sphere travel as far per revolution as a larger sphere?
Torque about what point? Your expressions predict that when the objects are on a horizontal plane (θ = 0) the torque is non-zero. Does that make sense? Also, how do you know that the force of static friction acting on each object is the same?
@kuruman
Right, my expression of the torque is not correct - it should have contained the radius as well and I should have used sine instead.
[tex]M = fm_{object}g\sin(\theta)R_{object}[/tex]
This will result in one R cancelling out.
Apart from that, I should have used the linear acceleration instead of the angular one, which makes me arrive at the conclusion that both spheres will need the exactly same amount of time to roll out of the plane.
f is the static friction coefficient.
@kuruman
f is the static fraction coefficient.
Nearly right.
[tex]M =F_fR_{object}[/tex]
where Ff is the frictional force, but that will only equal ##\mu_sm_{object}g\sin(\theta)## in the limiting case, where it is on the point of slipping.
Please explain what the coefficient of static friction has to do with anything. It comes into play only when two surfaces in contact are about to start sliding relative to one another. If the surfaces are not on the verge of sliding past each other (and there is no language in the problem that suggests that this is the case), the static friction is whatever is necessary to provide the observed acceleration.
Also, you did not clarify about what point you express the torque due to static friction. If it is about the pont of contact, this torque is zero (no lever arm); if it is about the CM, static friction is perpendicular to the lever arm, so ##\sin \theta =1##.
I assumed that the static friction is what causes the object to rotate. Should I have taken some other force of friction into account?
As for the the point about which I expressed the torque, I calculated it relatively to the CM of the object, hence - right, the sine will equal one.
There is no other friction present. However, the force of static friction acting on each object does not have the same value, therefore you cannot use the same symbol ##f## for all of them. So, if you wish to go this route, you need to find the force of friction on each object using the FBD method and Newton's 2nd law for both linear and rotational motion. An alternative that I would recommend is energy conservation.
That is correct.
What about choosing the axis of rotation in the point of contact of the object and the plane?
Then, there I would have to take into consideration the "drag force" which is a component of the force of gravity, and the force of friction would cancel out
then, the torque:
[tex]M = Rmg\sin(\theta)[/tex]
That's correct for the torque about the point of contact. Now what?
Likes ChessEnthusiast
Let's analyze the case of the cylinder.
Moment of inertia:
[tex]I = \frac{1}{2}mR^2 + mR^2 = \frac{3}{2}mR^2[/tex]
[tex] a = \frac{M}{I}R[/tex]
What about this attempt?
That's the linear acceleration. Can you simplify the expression using what you have for ##I## and ##M##?
[tex]a = \frac{2}{3}gsin(\theta)[/tex]
However, I'm worried that the acceleration does not depend on the friction coefficient.
As long as the rolling is without slipping the coefficient of static friction is irrelevant. The cylinder would take the same amount of time to reach bottom on a wooden incline as on a rubber-coated incline. It might be a good exercise for you to figure out the force of static friction on the cylinder. All you have to do is solve##F_{net}=ma## in which you already know ##a##.
Related to Inclined plane - a small sphere, a big sphere and a cylinder
1. How does the shape of the object affect its motion on an inclined plane?
The shape of the object affects its motion on an inclined plane because it determines the distribution of weight and the surface area in contact with the plane. A smaller sphere will have less weight and a smaller surface area, resulting in a faster and smoother motion compared to a larger sphere or a cylinder.
2. What is the relationship between the angle of the inclined plane and the speed of the object?
The angle of the inclined plane affects the speed of the object because it determines the component of the object's weight that is acting parallel to the plane. As the angle increases, the component of weight acting parallel to the plane also increases, resulting in a faster speed down the plane.
3. How does friction affect the motion of the objects on an inclined plane?
Friction plays a significant role in the motion of objects on an inclined plane. It opposes the motion of the object, making it slower and causing it to eventually come to a stop. The magnitude of friction depends on the surface materials and the weight of the object.
4. Can an object move up an inclined plane?
Yes, an object can move up an inclined plane if the force pushing it up the plane is greater than the component of its weight acting down the plane. This can be achieved by applying a force or using a machine like a pulley system.
5. How does the mass of the object affect its motion on an inclined plane?
The mass of an object affects its motion on an inclined plane because it determines the object's weight. A heavier object will have more weight, resulting in a slower and more gradual motion compared to a lighter object. However, the angle of the inclined plane also plays a role in determining the object's speed.
