Electrical Increasing current in an intercom circuit
The discussion centers around troubleshooting an electric lock that operates sporadically, likely due to insufficient current from an intercom system rated at 1.2Amps, while the cabling is only rated at 1Amp. The user seeks advice on boosting the current, considering using a relay powered by a 12V 2Amps DC transformer and appropriate cabling. It is confirmed that a relay is a suitable solution, allowing the lock to receive the correct voltage and current independently from the intercom. A diode is clarified as ineffective for increasing current. The user plans to wire the system with a 30A adapter for reliability, and there are discussions about ensuring proper connections and addressing potential mechanical issues with the lock. Additionally, intermittent operation could stem from misalignment or wear, although the lock is new. Overall, the focus is on ensuring adequate power supply and proper installation to resolve the lock's operational issues.
mpulis
TL;DR Summary
I have an intercom circuit with a pre-purchased lock. The intercom is rated at 1.2Amps while the lock needs 2Amps. How can I make them compatible?
Hi,
I have purchased an electric lock some months ago. Now I purchased an intercom system which is rated at 1.2Amps. The cabling is rated at 1Amp. The lock is working sporadically. I guess it is because of the current.
Is it possible that I boost the current received? Maybe through a relay? So basically power the lock with a 12V 2Amps DC transformer and use a 2Amp+ (AWG 18) cable while I send the power signal from the intercom to a relay switch?
Or it would be best to use a diode of sorts to increase the current?
As you might realize, I am quite a newbie in electronics, so please do spell out things for me, even at the risk of belittling me :)
Thanks beforehand
PS: My model is the 520
You need a relay fed by a separate power supply. A relay is a good idea even if the lock had the same rated current as the intercom. Just make sure that the power to the lock is correct for the lock. If the lock needs 12 volts, it gets 12 volts. If the lock needs AC (or DC), it needs AC (or DC). There is a huge difference between AC and DC when powering relay coils and locks.
No belittling implied. You recognized the problem and solution, and just needed some reassurance from somebody with more experience.
A diode will not increase the current.
Likes mpulis
Thanks for your reply and reassurance!
This is how I intend to wire everything.
The DC adapter for the relay and lock is actually a 30A adapter with 10A buffer over the 80% capacity so it can spare the extra 2A.
Much appreciated
If I were to buy this: https://www.ebay.co.uk/itm/DC-2V-24V-40A-5-Pin-Automotive-Changeover-Socket-Relay-Car-Bike-Van-Boat-Switch/312519193276?hash=item48c39872bc:m:mmwH6k_qlYR8mYUjPLmtwRg
how would I need to wire it because there are 6 cables in my diagram and all relays are 5. That means that the -ve from the power adapter goes straight to the lock right?
Right!
You stated that the lock operation is intermittent. In my experience of living and working in several buildings with electric door latches (locks), the usual cause of intermittency is wear or misalignment of the lock and/or the latch on the door.
The mating surfaces either get rough or have a groove worn in them so the lock can not release. The quick fix has been to replace the one with the obvious wear. This of course allows the remaining rough one to grind down the new piece, soon triggering another service call. If wear becomes a problem, replace both pieces!
Another problem, that depends on the lock/latch details, is weather stripping may apply enough opening force to the door that the lock cannot retract. Remount the lock so the weather stripping in not compressed so much.
Have Fun!
Tom
irrelevant recollection:
One building I lived in had a lock that worked fine in fair weather. After a rain it would not release. One time the manager was coming in as I was leaving... well trying to come in anyhow, it had rained the previous day. She complained about the lock and I said "That's an easy fix"... Here try it now.
When she asked what I did, I mentioned the rain and explained that most people have excess oil on their face next to their nose. I rubbed my finger next to my nose and transferred a little lubrication to the lock. She was still sputtering as I walked away.
Likes mpulis
Thanks Tom.
But this is a brand new lock so one would hope there is no wear and tear already ;)
When I tried it with a 30A power adapter, it opened without any issue so it really seems to be an issue with current. Hence why the relay should fix the issue.
Thanks both for your help!
Likes Tom.G
The idea is to use water to shift the centre of gravity of the pendulum by a small amount. The pendulum rod will have a tube closed at the bottom and open at the top. A second similar tube will be mounted nearby and will act as a reservoir. The water will be transferred using a peristaltic pump driven by a stepper motor and will travel via a thin flexible silicon tube. A loop arrangement will minimise friction at the pendulum's fulcrum. The silicon tube will extend to the bottom of the...
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Hot Threads
