Increasing Spin: Ice Skater's Formula Revealed
The discussion focuses on the physics behind an ice skater's increasing spin, specifically the conservation of angular momentum. Key factors include the angular inertia of the skater with arms and legs extended versus pulled in, which affects the rate of spin. When a skater pulls their limbs closer to their body, their moment of inertia decreases, leading to an increase in angular velocity. Calculating the exact spin rate requires knowledge of various parameters, including mass and distance. Understanding these principles helps explain how skaters achieve faster spins.
phredbo
any one know the formula for an ice skater in an increasing spin
Increasing rate of spin?
Jim
It's complicated. Since the spinner does work by pulling a leg and arms inwards, the angular kinetic energy increases. You would need to know the angular inertia with leg and arms extended and then pulled in. Then you'd also need to know the amount of mass, the rate of spin, distance pulled inwards ..., to determine the work done (force times distance) while pulling the leg and arms inwards.
For a single point mass, if the radius is decreased by 1/2 the speed of the mass increases by 2, and the centripital force increases by 8.
hi jeff many thanks for the quick reply. all the best phres
The formula, or the idea, which the OP perhaps wanted is the conservation of angular momentum. The initial ang mom =I1w1=final ang mom=I2w2.
As Jeff has said, a lot parameters have to be known for the actual calculation. But, as you must have noticed, if you pull in your arms and/or a leg, then I decreases, resulting in an increase of w, which means you are spinning faster. And vice versa.
reply to shooter
hi shooter heaps of thanks for the help in the spin formula I am new to the physics forum. I am still finding my way around
the web site. all the best..phredbo
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
