Indirect Proofs: Shaping the Proof
  • Thread starter Thread starter ConcealedDreamer
    Proof Proofs
Indirect proofs are a mathematical technique where one assumes the negation of the statement to be proved and works towards a contradiction. This method, known as "proof by contradiction," involves three key steps: assuming the opposite of the desired conclusion, applying logical reasoning to derive a contradiction, and concluding that the original assumption is false. By reaching a contradiction, the original statement is indirectly validated as true. Although it may seem counterintuitive initially, mastering indirect proofs can enhance problem-solving skills in mathematics. Practicing this approach can make it a valuable addition to one's mathematical toolkit.
ConcealedDreamer
Hey, anyone ever done indirect proofs? Maybe my school is a little weird, but we are doing those. IF you did, how do we shape the proof?
You have to assume the statement to be proved is false and then work towards a contradiction.
Indirect proofs are a common and useful method in mathematics. They involve proving a statement by assuming its negation and then reaching a contradiction. This allows us to indirectly prove the original statement is true.
To shape an indirect proof, we typically follow three steps:
1. Assume the opposite: We begin by assuming the opposite of what we want to prove. This is called the "proof by contradiction" approach.
2. Use logical reasoning: Next, we use logical reasoning to reach a contradiction. This can involve using previously proven theorems or definitions, as well as using the properties of numbers or geometric figures.
3. Reach a contradiction: Finally, we reach a contradiction, which proves that our original assumption must be false. This, in turn, proves that our original statement is true.
In summary, shaping an indirect proof involves starting with an assumption, using logical reasoning to reach a contradiction, and ultimately proving the original statement by contradiction. It may seem counterintuitive at first, but with practice, indirect proofs can be a powerful tool in your mathematical toolkit. Good luck with your proofs!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
