Induced charge in coil from other static coils?
The discussion centers on the feasibility of generating electricity in a coil using a series of static coils that are alternately switched on and off. It highlights that while mutual inductance can allow energy transfer between coils, significant coupling is dependent on their geometry and materials. The concept of "collecting" charge through inductors is clarified, emphasizing that induction is about the flux generated relative to current, not charge accumulation. The conversation also notes that a generator requires mechanical energy to produce electrical energy, and simply coupling electrical energy between coils does not generate new energy. Ultimately, the goal of inducing a moving magnetic field over a coil without moving parts is acknowledged, but practical limitations are discussed.
R3KR
Hello ALL,
I have a question about magnetism and generating electricity in a coil from a group of another coils that are alternately switched on/off (cascade).
Would a current be generated from a group of coils that are switched on and off in sequence, having another coil parallel to them to "collect" the charge ?
Ultimately, you would be repeating the same theory in a generator but with no moving parts... replace the magnets with a group of coils to perpetuate a magnetic "wave" past the collector coil.
Any input or questions welcome!
Please see attachment for visual explanation (rendered art work)
It'd depend on what you did to energize the peripheral
coils.
There'd be very little magnetic coupling between the
central coil and peripheral coils 1,2,6,7.
There'd be significantly weaker coupling between the
central one and 3,5.
Assuming 4 and the central coil are tightly magnetically
coupled they could share some reasonable mutual
inductance.
Anyway the coupled flux from any coil to any other
coil is a function of the mutual inductance of the coils
which is dependent on the geometry and materials and
winding details. If the coils have a geometrically weak
mutual inductance then the induced current in one from
a change in current in the other would be weak.
And there's no such thing as "collecting" charge with
inductors. Induction is the the flux generated relative to
the current flowing, that's all. Mutual inductance is the
flux generated in one circuit as a result of current in the
other circuit.
Also you talk about generators and generating -- the
function of a generator is to convert MECHANICAL energy
into electrical energy; it's the MECHANICAL work that's
done against the magnetic field that 'generates'
electrical power by converting it from mechanical power.
You can couple electrical energy from one coil to another
coil all day long (at a loss of energy due to resistance,
stray flux, eddy currents, et. al.), but you're just moving
existing electrical energy from one place to another
about the same as if you'd conected the circuits with
wires. To 'generate' electricity as in make more electric
than you already had, you'd need a source of mechanical
energy to convert into the electrical energy.
But if you're just asking if the coils would couple energy
from one to the other? Yes, in amounts depending on
the geometry / materials / resistance / circuits / currents.
Thank you for the detailed explanation!
There would be a dc source on the coils. Each coil would pulse for a short period then the next would be charged (pulse). but fast, maybe 100 times a second.
When you say "coupled flux" are you talking about the point at which the coil and magnet (in a generator) go past each other and the flux (form the magnet) moves through the coil and causes a current to flow ?
You're welcome.
What is the effect you're trying to achieve?
I don't think that there's anything about such
a physical arrangement that would be particularly
useful to construct in and of itself.
If you're just trying to couple electrical energy from
one coil to another you don't need to geometrically
arrange them akin to a rotor/stator type of arrangement.
That arrangement is just used in generators
because it's a physically spinning turbine that is being
pushed hard by a mechanical process that is doing the
work that is converted into electrical energy.
In motors it's used because it's the key point of
converting electrical energy to physical rotation energy.
If you're just looking for variable coupling of circuit
energies thatcan be done in a variety of ways without
a geometrical situation like that.
When I say coupled flux I do not mean to refer
in any way to a specific physical arrangement of
two coils, though geometry certainly does play
a part in dictating what the coupled flux will be.
Don't take this analogy TOO far (since it's inaccurate
in a lot of other ways) but JUST for the purpose
I am about to describe -- imagine there are two coils,
one is a shower-head and the other is a drain.
The geometry and physical materials
of the shower head and the environment it
is spraying into dictates the greometric pattern of
its spray. The amount of spray is dictated by
the flow rate of the water (current) going to the
shower head, and the current (flow rate) is driven
by the pressure/energy difference between the
pipe feeding the shower head and the space the
shower head sprays into -- that is the voltage.
So with a constant water flow rate (current) and a
fixed set of geometric and environmental circumstances
the shower head will always produce the same spatial
pattern of spray and the same flow rate of spray.
The spray of the showerhead is the magnetic flux,
and its spatial pattern of field density
(amount of spray passing through a given square inch
of space) is the main aspect one can measure it by
beyond its total quantity over all space.
Now position another coil (our 'drain hole')
somewhere in space. The drain hole will have a
certain size, a certain distance from the shower head,
a certain orientation angle relative to the shower head.
Depending on the factors of the drain's size/placement
and the shower head's spatial field density of 'spray'
(flux), some fraction of the flux from the shower head
may pass through the 'drain hole' that represents
another coil.
As is intuitively obvious, anywhere from as close to zero
as you could imagine to nearly the full amount of the
shower head's flux (spray) will pass through the
'drain hole' depending on the physical/geometric
factors I mentioned.
As is also intuitively obvious, if the shower's flux is
spread out at a very wide angle, it'll be very difficult
for much of its flux to pass through a drain hole if
the shower head isn't either right NEXT to the drain hole
in a face to face orientation, or even better, the shower
head could be stuck INTO the drain hole.
When the shower head is NEXT TO and FACE TO FACE
with the drain hole that's like two coils being face to
face and oriented in the best possible way to couple
given their separate positions.
When the shower head is stuck all the way into the
drain hole, that'd be more like winding one coil directly
on top of the other.
So the 'coupled flux' is just the total amoung of flux
that makes it down the drain hole given the setup
that exists.
The total flux is the total amount of flux emitted by
the shower head wherever it may go in space and
however much of it is coupled or NOT to the drain hole.
Any circuit in the universe has SOME mutual inductance
with any other circuit in the universe, but usually
unless they're RIGHT NEXT to each other or ON TOP
of each other, the coupling is very weak, as in a few
percent at best in many cases.
Even when they're literally on top of one another or
right next to each other, special design circumstances are
generally necessary to get the coupling factor to exceed
about 25%.
Now the inductance of a coil is how much
magnetic flux it produces for a given current flowing in it. This is an area where the shower head analogy breaks
down badly -- a shower head will emit the same flux
of water out as there's a flux (current) of water in the
pipe going into the head. In magnetics there's
a ratio known as 'the inductance' that determines how
much magnetic flux is generated by how much current
flowing in an inductor.
When I speak of mutual inductance, that refers to
the mutuality or coupling of current to flux between
two circuits. The 'mutual inductance' of the
shower head / drain is defined as the ratio of water
captured by the drain (the flux that goes THROUGH the
drain) to the total water current flowing in the shower
head. The current generates a certain amount of
total flux, but the MUTUAL flux is only that fraction of
the total flux that goes through the drain as opposed
to elsewhere.
So the coupling factor is coupled flux / total flux,
and the mutual inductance is
flux in the drain / current in shower head.
There's an important theorem in physics that says
that if you switched the roles of the drain and the
shower head, the MUTUAL inductance remains the same,
it's a mutual quantity, not one that's unique to going
from one direction to another -- that's another difference
in the shower head analogy to real magnetics.
BTW in a generator or motor any pole pieces that
aren't pretty close to DIRECTLY being next to each other
have essentially insignificant mutual coupling.
The motor/generator doesn't benefit from or use the
effect of there being an arc sequence of progressive
coils / fields that have some kind of elusive cumulative
effect.
The only relevant effect is between the two poles that
are in very close proximity, and the rest of them are
just there 'waiting' because at some LATER point they
WILL be in close proximity. Until then, the mutual
coupling is minor compared to that between the ones
that are very nearly aligned.
So the arrangement and sequence of your coils
is irrelevant, there will just be some minor amount of
mutual coupling between any given one and any given
other.
That mutual inductance from any given one to any
given other is the only thing that determines the effect
of a current in one to the flux in the other. The position
or presence of the others is entirely independent of that.
My main goal was to create a field that travels from 1 to 7 inducing a charge in the main coil. I was thinking that, like in a generator, the coil moves past the magnet and creates a charge in the coil.
To replace the magnet with a series of coils which do not move but create a magnetic field that travels across the head of the main coil.
My goal is to induce a moving magnetic field over a coil with no moving parts, there by inducing a charge in said coil
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
