Induced drag relation with speed
Induced drag changes with velocity due to its relationship with lift, as it is influenced by airflow around the wingtip. The induced drag force is proportional to the square of the velocity (V²), while the induced drag coefficient (Cdi) is affected by the lift force, leading to a proportionality of 1/V⁴. The drag formula indicates that drag is influenced by factors such as density, reference area, and speed, but the drag coefficient itself remains constant with speed. Understanding these relationships clarifies why induced drag behaves differently than other forms of drag. The discussion highlights the complexities of aerodynamic drag mechanisms and their dependencies on various factors.
Owells
Hi everyone. I was wondering if you guys could explain me why I saw people say that:
Induced drag changes for a factor of 1/V2
Induced drag coefficient for a factor of 1/V4
If I don't make any mistakes, Drag = 1/2 rho * S * V² * Cd.
Manipulating the formula I find, 1/Cd = 1/2 rho * S * V² * Drag so here we can see that Cd inversely proportional to V², not V⁴.
And I still find that Drag is proportional to V² so why it's different with Induced Drag and Cdi ?
The drag coefficient doesn't change with speed. It includes everything that influences drag EXCEPT density, some predefined reference area, and speed.
Yes, maybe I misspoke, I know that drag is influenced by the design of the airfoil ect but let's pretend that we study an airfoil, I learnt that the drag formula was the same that the lift formula. So I don't understand why Induced drag change for a factor of 1/V² and why Cdi for a factor of 1/V⁴
Owells said:
... so why it's different with Induced Drag and Cdi ...
There are two different forms of drag mechanism.
The profile drag is due to airflow passing the wing, that also generates lift.
The induced drag is due to airflow around the wingtip, the end of the wing. That unwanted flow is normally from below the wing, to above the wing.
I understand better now.
The induced drag ##F_{di}## is ##\frac{1}{2} \rho C_{di}A_i v^2##. We already said ##C_{di}## includes everything that influences the drag force but ##\rho A_i## and speed. The lift force influences the induced drag force. No lift force, no induced drag force. Double the lift, you will [approximately] double the induced drag force. If this is what we observed then ##C_{di}## is proportional to the lift force ##\frac{1}{2}\rho C_L A_L v^2## or:
$$F_{di} = \frac{1}{2} \rho \left(C_{di*} \frac{1}{2}\rho C_L A_L v^2\right) A_i v^2$$
$$F_{di} = \frac{1}{4} \rho^2 C_{di*} C_L A_L A_iv^4$$
Where ##C_{di*}## is a coefficient including everything that is affecting the induced drag force excluding the lift coefficient, reference areas, density, and speed.
In general it does, but there are problems where we neglect this.
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
