Induced EMF Problem: Find Emf & Current in Square Coil
The discussion revolves around calculating the induced emf and current in a square coil formed from a circular coil in a changing magnetic field. The initial parameters include an induced emf of 0.80 V and a current of 3.2 A in the circular coil. The user incorrectly calculated the area of the square coil and was guided to consider the circumference of the circular coil to determine the side length of the square. By reforming the wire into a square, the area changes, affecting the induced emf. The conversation highlights the importance of correctly calculating the area when transitioning between different coil shapes.
sandycow
A magnetic field is perpendicular to the plane of a single turn circular coil. The magnitude of the field is changing so that the emf of 0.80 V and a current of 3.2 A are induced in the coil. The wire is then re-formed into a single turn square coil, which is used in the same magnetic field (again perpendicular to the place of the coil and with the magnitude changing at the same rate). What emf and current are induced in the square coil?
emf= ΔB/Δt*A
I used the equation emf= ΔB/Δt*A. with the two areas πr^2 and 4r^2 and i thought that since they were in the same plane with the rate of change in the magnetic field the same, i could do this... 0.80V/πr^2 = emf of the square/ 4r^2 and then solve for the emf of the square since the radius cancels. my teacher gave us the answer and what i got was not correct so I am not sure which equations I am suppose to use to solve this?
Hi sandycow, welcome to PF.
Your calculation of the area of the square is wrong.
What is the circumference of the given circular coil? Straighten the wire, and reform it as a square. What will be the length of each side of the square? What is the area of the square?
ohhhhh. i get it haha thanks that was such an oversight.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
