Inelastic collisions between two blocks
In an inelastic collision problem, a 2.0 kg block moving at 1.0 m/s is struck by a second block moving at 4.0 m/s, resulting in both blocks moving together at 2.0 m/s. The conservation of momentum equation is applied to find the mass of the second block. After setting up the equation and simplifying, it is determined that the mass of the second block is 1 kg. The discussion emphasizes the importance of correctly applying the conservation of momentum principle. The participants express satisfaction with the solution process and the learning experience.
lilblevs11
A 2.0 kg block slides along a frictionless surface at 1.0 m/s. A second block, sliding at a faster 4.0 m/s, collides with the first from behind and sticks to it. The final velocity of the combined blocks is 2.0 m/s. What is the mass of the second block?
law of conservation of momentum...
m1u1 + m2u2 = m1v1 + m2v2
(2 kg * 1 m/s ) + (m2 * 4 m/s) = (2kg + m2) 2.0 m/s
2 J + (4 m/s m2) = 4 J + (2.0 m/s m2)
4 m/s m2 = 2 J + (2.0 m/s m2)
now I'm lost...
Just finish your algebra
by the way kgm/sec is not joule, it's just kg m/sec, which is the same as N sec
so you have the equivalent of
4m = 2 + 2m
subtracting 2m from both sides
2m = 2
m = 1kg
Thanks netgypsy... now i feel like a true student. haha
Good job!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
