MHB Inequality Challenge: Prove 1/44 > 1/1999
The discussion focuses on proving the inequality $$\frac{1}{44}>\left(\frac{1}{2}\right)\left(\frac{3}{4}\right)\left(\frac{5}{6}\right)\cdots\left( \frac{1997}{1998}\right)>\frac{1}{1999}$$ using mathematical induction and manipulation of products. The product $$\frac{1}{2}\frac{3}{4}\cdots\frac{1997}{1998}$$ is denoted as x, leading to the conclusion that $$x^2<\frac{1}{1999}$$ implies $$x<\frac{1}{44}$$. An inductive proof is provided to show that $$P_n > \frac{1}{2n+1}$$ holds for all n, confirming the second part of the inequality. The thread effectively demonstrates the relationships between the fractions and establishes the required inequalities.
anemone
MHB
POTW Director
Show that $$\frac{1}{44}>\left(\frac{1}{2}\right)\left(\frac{3}{4}\right)\left(\frac{5}{6}\right)\cdots\left( \frac{1997}{1998}\right)>\frac{1}{1999}$$
Mathematics news on Phys.org
For the first one,
$$\left(\frac{1+1}{2+1}\right)\cdots\Big(\frac{1997+1}{1998+1}\Big)>\Big(\frac{1}{2}\Big)\Big(\frac{3}{4}\Big)\Big(\frac{5}{6}\Big)\cdots\Big(\frac{1997}{1998}\Big)
$$\Big(\frac{2}{3}\Big)\Big(\frac{4}{5}\Big)\cdots \Big(\frac{1998}{1999}\Big)>\Big(\frac{1}{2}\Big).\Big(\frac{3}{4}\Big)\Big(\frac{5}{6}\Big)\cdots\Big(\frac{1997}{1998}\Big)$$
$\text{let,}$
$$\frac{1}{2}\frac{3}{4}\frac{5}{6}\cdots\frac{1997}{1998}=x$$
$$\frac{1}{x\cdot1999}>x$$
$$x<\frac{1}{44+x}$$
$\text{hence,}$
$$x<\frac{1}{44}$$
The other inequality is easily proved by induction. Let $P_n = \Bigl(\dfrac{1}{2}\Bigr)\Bigl(\dfrac{3}{4}\Bigr) \cdots \Bigl(\dfrac{2n-1}{2n}\Bigr).$ Then $P_n > \dfrac{1}{2n+1}$.
Proof. The base case $n=1$ certainly holds. Assuming the inductive hypothesis, $$P_{n+1} = P_n\Bigl(\dfrac{2n+1}{2n+2}\Bigr) > \dfrac{1}{2n+1}\Bigl(\dfrac{2n+1}{2n+2}\Bigr) = \dfrac{1}{2n+2} > \dfrac{1}{2n+3},$$ which completes the inductive step.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
