Inequality - find the largest K in (a+b+c+d)^2≥Kbc
  • MHB
  • Thread starter lfdahl
  • Tags
    Inequality
In summary: Thankyou, Albert, for your participation. I think, the best, I can do, is to refer to Opalgs answer, and my short reply.I am interpreting the question to mean that we are looking for the largest value of $K$ such that $(a+b+c+d)^2 \geqslant K b c$ for all real numbers $a,b,c,d$ satisfying $0 \leqslant a \leqslant b \leqslant c \leqslant d$.The numbers $a=0$, $b=c=d=1$ satisfy the given conditions. With those values, the inequality becomes $9\geq
lfdahl
MHB
749
Suppose, the four real numbers $a,b,c$ and $d$ obey the inequality:$(a+b+c+d)^2 \ge K b c$, when $0 \le a \le b \le c \le d$.Find the largest possible value of $K$.
Mathematics news on Phys.org
my solution:
$K\leq \dfrac {(a+b+c+d)^2}{bc}$
$for \,\, a\leq b\leq c\leq d$
$if \,\, a,b,c\rightarrow 0$
$k \,\,depends \,\, on \,\, d\,\, only$
$so \,\, max(K)=\infty $
[sp]The numbers $a=0$, $b=c=d=1$ satisfy the given conditions. With those values, the inequality becomes $9\geqslant K$. On the other hand, the inequality $(a+b+c+d)^2 \geqslant 9 b c$ holds for all $a,b,c,d$ satisfying the given conditions.
To see that, notice first that the left side of the inequality becomes smaller if we put $a=0$ and $d=c$. So it will be sufficient to show that $(b+2c)^2 \geqslant 9bc$ whenever $0\leqslant b\leqslant c$. But $$(b+2c)^2 - 9bc = 4c^2 - 5bc + b^2 = (c-b)(4c-b),$$ and that is clearly $\geqslant 0$ whenever $c\geqslant b\geqslant 0.$
Therefore the largest possible value for $K$ is $9$.[/sp]
Thankyou very much, Opalg for another amazingly sharp and clear - and of course correct - answer! I also want to say, that I´m sorry, that I did not express my problem clear enough.
- - - Updated - - -
Albert said:
my solution:
- - - Updated - - -
my explanation of this question is the following
first condition $0\leq a\leq b\leq c\leq d $ is given,and to satisfy the inequality
$\dfrac {(a+b+c+d)^2}{bc}\geq {K}$,find $max(K)$
Is this interpretation reasonable ?
so we will have different answer to this question according to alien translation
ex :if a=b=c=d=1 then k=16, so k will be undefined and max(K) will be infinity
under this interpretation
I think this problem should be considered as an open question
how about $a=0,b=c=0.1, d=1$
we have $(0+0.1+0.1+1)^2\geq K\times 0.1\times 0.1$
also satisfy the given inequility $1.44\geq 0.01K,and \,\, K\leq 144$
of course if we set $a=0,b=c=d=0.1,\,\,then\,\, K=9$
so in my opinion $9$ should be $min(K)$ instead of $max(K)$
for $a,b,c\in R $
and the inequility should be $(0\leq a<b\leq c\leq d)$
first condition $0\leq a\leq b\leq c\leq d $ is given,and to satisfy the inequality,
Hi, Albert
I think, the point is, that the $K$-value can only be determined, when we consider all possible values of $a,b,c$ and $d$.
For example: Letting $a=b=c=d=1$ does not imply, that $K = 16$. The case: $a = 0$, $b=c=d=1$ should also obey the
inequality. I guess, that´s why Opalg underlines "all" ($a, b, c, d$ values) in his interpretation of the problem. It is true, that if we stick to some few special cases, $K$ will be undefined, as you notice. But using only some cases to determine $K$ is a misinterpretation of the problem. I admit, that my way of formulating the problem is not clear enough, and I´m sorry for this.
for $a,b,c\in R $
Hello again, Albert!
It is indeed a reasonable consideration: whether we look for a maximum or a minimum value of $K$!
I´d say, we are looking for a maximum value, because:
Any value of $K$ below $K_{max}$ makes the inequality statement true, thus $K \in ]-\infty; K_{max}]$ implies, that any choice of $a,b,c,d$ (of course still with the restriction: $0 \le a \le b \le c \le d$) is accepted/valid. In other words: It is easy for us to make the inequality true, we can simply pick any suitable low $K$. But the opposite is not true: We cannot pick an arbitrary high $K$-value, simply because we have to consider all possible values of $a,b,c$ and $d$.
FAQ: Inequality - find the largest K in (a+b+c+d)^2≥Kbc
1. What is the purpose of finding the largest K in the inequality (a+b+c+d)^2≥Kbc?
The purpose of finding the largest K is to determine the minimum value of K that satisfies the given inequality. This value of K represents the maximum amount that the product of bc can be less than the square of the sum of a, b, c, and d.
2. How do you solve for the largest K in the inequality (a+b+c+d)^2≥Kbc?
To solve for the largest K, you can expand the square of the sum and rearrange the terms to get Kbc on one side of the inequality. Then, divide both sides by bc to isolate K. The resulting value of K will be the largest possible value that satisfies the inequality.
3. Can the inequality (a+b+c+d)^2≥Kbc be solved algebraically?
Yes, the inequality can be solved algebraically by expanding the square of the sum and rearranging the terms to isolate K. However, the resulting expression may be complex and difficult to solve for K.
4. How can the largest K in the inequality (a+b+c+d)^2≥Kbc be used in practical applications?
The largest K can be used in various real-life scenarios where the sum of a, b, c, and d represents a total amount and the product of bc represents a budget or limit. The value of K represents the maximum amount that the budget can be below the total without violating the given inequality.
5. Is it possible for the largest K in the inequality (a+b+c+d)^2≥Kbc to be a negative number?
No, the largest K in the inequality must be a positive number. This is because the square of the sum of any real numbers will always be positive, and the product of two negative numbers is also positive. Therefore, K must be positive in order for the inequality to hold true.
