Infimum of integral of open set
  • Thread starter Thread starter lahuxixi
    Integral Set
lahuxixi
I have already done part a and b. Part a is easy, for part b, i let the anti-derivative of f to be k(t)+c and arrive at the answer that F(f)= 1/2+ 2*k(1/2) - k(1). But i don't know how to do the next part, can anyone give me a hint? the question c ask me to show that the infimum of F is 0 and it is never attained on A.
Hint: For F(f) to be near zero then f needs to be near 0 on [0,1/2) and near 1 on (1/2,1].
It's conceptually pretty easy. Both integrands are nonnegative. You can make it as small as you want by jumping from f=0 on most of [0,1/2] to f=1 on most of [1/2,1]. Is that enough of a hint?
but in that case, F(f) will be -1/2,right? I am sorry but i don't really understand the hint,can you give a more specific "hint"?(i know,im bad at this)
I don't know where you got that since "f" was not given explicitely. It sounds to me like you are integrating f from 0 to 1 rather than f from 0 to 1/2 and then 1- f from 1/2 to 1.
Suppose f(x)= 0 for 0\le x\le .4, f(x)= 5(x- .4) for .4\le x\le .6, f(x)= 1 for .6\le x\le 1. That is, f is 0 from 0 to .4, then the straight line from (.4, 0) to (.6, 1), then is 1 from .6 to 1. What is the integral of that?
Now, do the same thing for , say .45 instead of .4 and .55 instead of .6- f(x)= 0 for 0\le x\le .45, is the straight line from (.45, 0) to (.55, 1), then 1 from .55 to 1. What is the integral of that? (You don't even need to write out the formula for the function- the integral is the area of a right triangle.)
What happens as you keep moving those two points toward x= .5?
thank you very much for this, i have been trying to do this question for a whole day already.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
