Infinite Square-Well Potential Problem
  • Thread starter Thread starter interxavier
    Infinite Potential
An electron in an infinite square-well potential of width 0.5 nm, initially in the n = 4 state, can emit photons as it transitions to the ground state. The energy levels are defined by the equation En = -Eo/n^2, allowing the calculation of energy differences between states. The energy of the emitted photons corresponds to the difference in energy between the initial and final states of the electron. To find the photon energies, one must relate the energy of the emitted photons to the energy difference of the electron states. Understanding these relationships is crucial for solving the problem effectively.
interxavier
An electron is trapped in an infinite square-well potential of width 0.5 nm. If the electron is initially in the n = 4 state, what are the various photon energies that can be emitted as the electron jumps to the ground state?
The Schroedinger Equation:
-[STRIKE]h[/STRIKE]/2m*d^2Y/dx^2 + V*Y = E*Y
En = - Eo/n^2
My understanding is that Y(0) = Y(L) = 0, making them the boundary conditions.
You need to find the solution for Y by solving the Schroedinger Eq'n, which is a Differential Equation.
I'm totally blank afterwards.
Are you sure it's necessary to solve the infinite-square-well problem from scratch? It's probably solved in your textbook or notes, and you can use those results to solve this problem.
What am I supposed to do in this problem?
Relate the energy of the emitted photons to the energy of the electron.
Okay, the energy of the electron, because it's in state 4, is E4 = -Eo/4^2. What about the photons? I know the energy of a photon is E = hf but how do I apply this to the problem?
Well, figuring that out is the point of the problem. The emitted photon carries energy away, right? Where does the energy come from and what happens to the electron?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
