Initial condition for Schrödinger equation
kengrimwood
(If the equation below do not appear correctly, you can read all of the question in the attached file.)
Solving the time dependent 1D Schrödinger equation, one can show that in all points (x,t),
i\bar{h}\frac{\partial}{\partial t}\Psi(x,t)=-\frac{\bar{h}^2}{2m}\frac{\partial^2}{\partial x^2}\Psi(x,t)+V(x)\Psi(x,t)=E\Psi(x,t)
for a certain value of the energy E. This means that the wave function is necessarily an eigenfunction of the hamiltonian operator.
On the other hand, we may specify an initial condition for this problem. My question is: what if the initial condition DOES NOT verify the above equations. Namely, if -\frac{\bar{h}^2}{2m}\frac{\partial^2}{\partial x^2}\Psi(x,t)+V(x)\Psi(x,t) is not proportional to \Psi(x,t).
Does it mean that not all initial conditions will give a solution or am I wrong somewhere? Thank you for your help!
Your assertion that all possible wavefunctions are eigenfunctions of the Hamiltonian is wrong. You mixed the stationary and the non-stationary Schroedinger equations. The stationary one is an eigenvector equation and gives you a basis of the solution space together with the eigenfrequencies. Any solution to the time dependent S.E. can be decomposed into that eigenbasis and each component then evolves with stationary magnitude and given angular frequency for the phase.
Cheers,
Jazz
The equations did not display correctly originally because you had a blank space inside each [tex ] and [/tex ] tag, as shown here. I removed those spaces for you. (It's rather difficult to show those tags as ordinary text because the forum software insists on interpreting them as actual tags and then hiding them!)
For more information about using LaTeX here, see:
https://www.physicsforums.com/showthread.php?p=3977517#post3977517
kengrimwood said:
My question is: what if the initial condition DOES NOT verify the above equations. Namely, if -\frac{\bar{h}^2}{2m}\frac{\partial^2}{\partial x^2}\Psi(x,t)+V(x)\Psi(x,t) is not proportional to .
There can be many solutions to the T.I.S.E(including non-normalizable), but normally only those are of any interest which are proportional to \Psi(x,t)(eigenfunction), since only these solutions give you the E(eigenvalue) as constant, which in turn are stationary states with definite energy when we apply the initial conditions.
Plainly speaking, if I am getting your problem right, if you cannot solve for the initial wave function, then you cannot determine its solution after time 't'. Its because the time dependent solution is because we consider that after finding the initial solution, we can find the wave evolved over time through the initial one. Its too hard to right the mathematics from mobile, so i just conveyed my opinion on words.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
