MHB Initial value problem of the wave equation
evinda
MHB
Hello! (Wave)
I want to prove that if for the initial value problem of the wave equation
$$u_{tt}=u_{xx}+f(x,t), x \in \mathbb{R}, 0<t<\infty$$
the data (i.e. the initial data and the non-homogeneous $f$) have compact support, then, at each time, the solution has compact support.
I have thought the following.
Suppose that we have the initial data $u(x,0)=\phi(x)$ and $u_t(x,0)=\psi(x)$.
The functions $f, \phi, \psi$ have compact support, meaning that the functions are zero outside a bounded set $[a,b]$.
The solution of the initial value problem is given by
$$u(x,t)=\frac{1}{2}[\phi(x+t)+\phi(x-t)]+\frac{1}{2}\int_{x-t}^{x+t} \psi(y) dy+\frac{1}{2} \int_0^t \int_{x-(t-s)}^{x+(t-s)} f(y,s)dy ds$$
Let $t=T$ arbitrary.
Then
$$u(x,T)=\frac{1}{2}[\phi(x+T)+\phi(x-T)]+\frac{1}{2}\int_{x-T}^{x+T} \psi(y) dy+\frac{1}{2} \int_0^T \int_{x-(T-s)}^{x+(T-s)} f(y,s)dy ds$$
We check when $u(x,T)=0$.
We have $u(x,T)=0$ when
  1. $x+T, x-T \in \mathbb{R} \setminus{[a,b]}$,
  2. $x-T,x+T<a$ or $x-T,x+T>b$,
  3. $x-(T-s)<a$ and $x+(T-s)<a$ or $x-(T-s)>b$ and $x+(T-s)>b$,
The second and third point holds for $x<a-T$ and $x>b+T$.
Thus $u$ is non-zero outside $[a-T,b+T]$ and $u$ has compact support. Is everything right? (Thinking)
evinda said:
Hello! (Wave)
Hey evinda! (Wave)
I haven't figured everything out yet, but... how could you tell that $\phi$ and $\psi$ have compact support? (Wondering)
I like Serena said:
Hey evinda! (Wave)
This is given that the initial data have compact support... (Thinking)
Ah okay.
Then it looks right to me! (Happy)
You may want to clarify that the 3 bulleted numbers correspond to the 3 terms in the solution though. (Nerd)
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
