Initial Velocity - Projectile Motion
The discussion focuses on calculating the initial velocity of a firework shell that explodes at a height of 600 ft after approximately 5 seconds. The user has attempted to use kinematic equations to derive the initial velocity but seeks clarification on the calculations and the impact of air resistance. It is confirmed that the first equation can determine the vertical component of velocity, but the horizontal component cannot be calculated with the given data. The user also expresses interest in incorporating air resistance into their calculations for greater accuracy. Overall, the conversation emphasizes the complexities involved in projectile motion and the need for precise calculations in such scenarios.
vaio23
Hello,
My end goal is to calculate the vertical and horizontal displacement of an object that explodes in the air e.g. a firework. However, I am having difficulty deriving the initial velocity of the object. I know the approximate time is 5.0 seconds from the ground to explosion and the height is 600 ft (182.88m).
So far I have used the equations v(i) = (d / t) - [(a * t) / 2] and V(i) = a*t. Any help would be greatly appreciated.
The initial velocity to fire is the same as the velocity an object would be traveling at after falling from its peak altitude.
Formulas and calculator can be found here:
http://www.gravitycalc.com/
If the time is 5 seconds, the altitude would be 123 meters and the initial velocity would be 49 meters/second.
If the altitude is 183 meters, the time is 6.1 seconds at an initial velocity of 59 meters/second.
The 600 ft (182.88m) is the height in which the fireworks breaks and we do know from industry averages that a shell of this size takes 5.0 seconds to reach this height. It is likely that the maximum height is greater than 600 ft which would mean the shell still has a final velocity at the time of break. Is there a way to calculate for these two unknowns?
The first equation is fine. That will tell you the initial velocity (vertical component only) which will allow the projectile to reach a given height in a given time. Note that this neglects air resistance, which may well be significant.
There's no way to determine the horizontal component of velocity from the given data.
Thank you for your response it was a big help. If I wanted to become more precise and incorporate air resistance into my formula how would I do this. It was been a long time since I've done something like this.
Known Values:
Time = 3.8
Aprox Height = 300 Ft
Initial velocity = 140 Ft/s
Launch Angle = 75 Degrees
Weight of shell = 3.5 lbs
Also, the radius of the sphere is 3 inches
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
