I Injection radius in a Penning trap
  • I
  • Thread starter Thread starter Malamala
Malamala
Hello! When an ion is injected in a Penning trap, how well is its initial radius know? I understand that usually people use cooling mechanism to reduce that radius as much as needed, but I was wondering in the beginning, before the cooling starts, how small is the radius of the ion and how well is it know? Thank you!
Not sure I understand the question. It isn't known until it's measured. Typically the initial position of an ion depends on how it's loaded to the trap. I am sure the probability distribution for loading an ion would be very different in the ALPHA experiment compared to the electron g-2 measurement (for example).
The most general answer I can give is that the expectation value of the radial position of the ion is determined by the velocity distribution of the ions being loaded and trapping potential (if loading axially) or the strength of the magnetic field (if loading radially).
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
