MHB Injective linear mapping - image
mathmari
MHB
Hey! :o
Let $F$ be a field and $V,W$ finite-dimensional vector spaces over $F$.
Let $f:V\rightarrow W$ a $F$-linear mapping.
We have to show that $f$ is injective if and only if for each linearly independent subset $S$ of $V$ the Image $f(S)$ is linearly independent in $W$. I have done the following:
If $f$ is injective we have that $kern (f)=\{0\}$, right?
Since $\dim (kern(f))+\dim (im(f))=\dim V$ and since $\dim (kern (f))=0$ we get that $\dim (im(f))=\dim V$.
It holds that $\dim im(f) = \dim W$, right?
So, we get that $im (f) = W$, or not? (Wondering)
Does this help us to get the desired result? (Wondering)
Since $S$ is linearly independent we get that $\sum_{i=1}^nc_is_i=0 \Rightarrow c_i=0, \forall i$, where $s_i\in S$.
Then since $f$ is linear we have that $f\left (\sum_{i=1}^nc_is_i\right )=f(0) \Rightarrow \sum_{i=1}^nc_if(s_i)=0$.
How do we continue from here? How do we use the fact that $f$ is injective? (Wondering)
Take the image of a linearly independent set and assume it is not independent you should be able to get a contradiction using the fact you gave that injective means the kernal is zero.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
