Calculators Inputting Uneven Equations on the TI-89 Calculator?
  • Thread starter Thread starter Holmez
    Input Ti-89
The discussion revolves around using the TI-89 calculator to solve a system of three equations with varying numbers of parts. The equations involve forces represented by variables F_ax, F_ay, and F_c, with specific values substituted for constants. The user initially struggled with inputting the equations correctly into the Simultaneous Equation Solver due to the differing structure of the equations. After some guidance, the user successfully inputted the equations and achieved the desired results. The conversation highlights the calculator's utility for simplifying arithmetic while emphasizing the importance of understanding the underlying problem-solving process.
Holmez
I have problems with finding out how i can insert these three equations:
index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=399594.jpg
into the TI-89 calcualtor, so i get the 3 answers in the bottom of the picture. I know how to do it if the 3 equations have the same amount of parts/sections, but like you see here the fir equation has 2 parts, but the 2 others have 3 parts. I use the program called Simultaneous Eqn Solver on my TI-89.
Computer science news on Phys.org
Actually, each equation has four parts:
0F_{ax}+ 0F_{ay}+ \frac{8}{\sqrt{20}}F_c+ \frac{800(16)}{\sqrt{20}}= 0
1F_{ax}+ 0F_{ay}+ \frac{-2}{\sqrt{20}}F_c+ \frac{800(4)}{\sqrt{20}}= 0
0F_{ax}+ 1F_{ay}+ \frac{4}{\sqrt{20}}F_c+ \frac{800(2)}{\sqrt{20}}= 0
By the way, 800(16)= 12800, 800(4)= 3200, 800(2)= 1600, and \sqrt{20}= 2\sqrt{5}.
Calculators are good for doing tedious arithemetic. Don't expect them to do your thinking for you! These are close to being trivial to do by hand and it would be good practice. Solve the first equation for F_c, then put that value into each of the other equations.
thanx for the help :)
My teacher says that we should input it into a calclator, so we don't need to solve the equations manualy.
i got it to work now when i inputed the equations the way you wrote them :)
Well, the date has now passed, and Windows 10 is no longer supported. Hopefully, the readers of this forum have done one of the many ways this issue can be handled. If not, do a YouTube search and a smorgasbord of solutions will be returned. What I want to mention is that I chose to use a debloated Windows from a debloater. There are many available options, e.g., Chris Titus Utilities (I used a product called Velotic, which also features AI to prevent your computer from overheating etc...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
16K
9K
11K
