MHB Integer Challenge: Proving $2A, A+B, C$ integers for $f(x)=Ax^2+Bx+C$
  • Thread starter Thread starter kaliprasad
    Challenge Integer
The discussion focuses on proving that if the quadratic function f(x) = Ax^2 + Bx + C yields integer values for all integer inputs x, then the expressions 2A, A + B, and C must also be integers. Participants explore various mathematical approaches to establish this relationship and discuss the converse, which states that if 2A, A + B, and C are integers, then f(x) will produce integer outputs for all integers x. The conversation includes different proofs and methods to validate these claims, emphasizing the importance of integer properties in polynomial functions. Overall, the thread highlights key mathematical principles related to quadratic functions and integer outputs. The proofs provided contribute to a deeper understanding of the conditions under which these integer relationships hold.
kaliprasad
MHB
Let $f(x) = Ax^2 + Bx +C$ where A,B,C are real numbers. prove that if $f(x)$ is integer for all integers x then
$2A, A + B, C$ are integers. prove the converse as well.
Mathematics news on Phys.org
kaliprasad said:
Let $f(x) = Ax^2 + Bx +C---(1)$ where A,B,C are real numbers. prove that if $f(x)$ is integer for all integers x then
$f(0)=C \in Z---(2)$
$f(1)=A+B+C\in Z---(3)\,\,\therefore A+B\in Z$
$f(-1)=A-B+C\in Z---(4)$
$(3)+(4): 2A+2C\in Z\,\,\therefore 2A\in Z$
$(3)-(4):2B\in Z---(5)$
prove the converse :
if $x=2k\in Z$
then $f(x)=4k^2A+2Bk+C\in Z$
if $x=2k+1\in Z$
then $f(x)=4k^2A+4Ak+2Bk+A+B+C\in Z$
if $x=2k\in Z$
if $x=2k+1\in Z$
Above is a good solution different from mine which is as below
we have $f(x) = A x^2 + Bx + C = A (x^2-x) + (A+B) x + C=2A\frac{x(x-1)}{2} + (A+B) x + C$
now x and $\frac{x(x-1)}{2}$ are integers for integer x. so if (A+B),2A and C are integers the $f(x)$ is integer for integer x
if f(x) is integer for all x then $f(0) = C$ is integer.
$f(1) = (A+B) 1 + C$ is integer so $A+B$ is integer
$f(2) = 2A + 2(A +B) + C$ is integer so $2A$ is integer
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
