MHB Integer Find x,y for $y^2+2y=x^4+20x^3+104x^2+40x+2003$
  • Thread starter Thread starter kaliprasad
    Integer
kaliprasad
MHB
Find all solutions in integers $x,y$ of the equation $y^2+2y= x^4+20x^3+104x^2 + 40x + 2003$
Mathematics news on Phys.org
kaliprasad said:
Find all solutions in integers $x,y$ of the equation $y^2+2y= x^4+20x^3+104x^2 + 40x + 2003-----(1)$
let $p=x^2+10x=x(x+10)-----(2)$
from (1) we have :$y(y+2)=p^2+4p+2003$
$\therefore (y+1)^2=p^2+4p+2004---(3)$
from $(2):x^2+10x-p=0---(4)$
for $x,y$ both are intgers we get :$p>0,$ and $p$ may take values from the following lists:
$11(1\times 11),24(2\times 12),39(3\times 13),----,119(7\times 17)----,n\times (n+10)$
from $(3) : p^2+4p+2004$ is a perfect square
we may assume $p^2+4p+2004=(p+10)^2\rightarrow p=119$
hence $(x,y)=(7,128) \, (7,-130)$
or $(x,y)=(-17,128) \, (-17,-130)$
Though the ans is right but
is a weak assumption and some solutions could have been missing
in fact we can set:$p^2+4p+2004=(p+k)^2$
here $k$ must be even and $2< k \leq 44$, and $p=n(n+10), n\geq 1$
and we obtain :$p=n(n+10)=\dfrac {2004-k^2}{2k-4}---(*)$
the only solution for $(*)$ is $k=10, p=119$
My solution
Add 1 to both sides to get
$(y+1)^2 = x^4+20x^3+104x^2+40x+2004 = x^4+20x^3+ 104x^2+40x+ 4 + 2000 = (x^2+10x+2)^2 +2000$
or $(y+1)^2 - (x^2+10x+2)^2 = 2000$
for the above to have solution we need to have $(y+1)$ and $(x^2+10x+2)$ both should be even or odd and as $(x^2+10x+2) = (x+5)^2-23$ so
the $2^{nd}$ number with need to be 23 less than a perfect square.
so let us find (t,z) which are $(\pm501,\pm499),(\pm252,\pm248),(\pm129,\pm121),(\pm105,\pm95),(\pm60,\pm40),(\pm45,\pm5)$ out of which
only z = 121 which 23 less than is a perfect square
so we get
$y+1= \pm 129, (x+5) = \pm 12$ giving 4 solutions ($y=-130, x = - 17$), ($y= -130,x= 7$), ($y=128,x=7$),($y= 128, x= -17$)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
