Integral involving powers of trig functions
In summary, the integral involving powers of trigonometric functions often requires the use of specific techniques such as substitution, integration by parts, or trigonometric identities. These integrals can be classified based on the powers of sine and cosine, and methods such as reducing the power through identities or transforming the integral into a more manageable form are commonly employed. The goal is to simplify the integral into a solvable format, making it possible to find the antiderivative or evaluate the definite integral effectively.
Memo
35
∫(sinx+sin^3x)dx/(cos2x)
cos2x=2cos^2x-1
Could you check if my answer is correct? Thank you very much!
Is therea simpler way to solve the math?
Memo said:
Homework Statement: ∫(sinx+sin^3x)dx/(cos2x)
Relevant Equations: cos2x=2cos^2x-1
You can do that yourself by differentiating your answer and checking you get the original integrand.
Your method looks good to me. Maybe there's a trick, but not always.
Likes Gavran
Could you tell me how?
If you integrate a function f(x) and get an antiderivative F(x) + C, you can check your answer by differentiating F(x). If your antiderivative is correct, the result will be f(x).
In symbols...
If ##\int f(x) dx = F(x) + C##, then ##\frac d{dx}\left(F(x) + C\right) = f(x)##
Likes WWGD and PeroK
In symbols...
It appears that I was wrong
## \text { The method is good, but there are two mistakes. } ##
## \text { The first one is: } u ^ 2 \text { is missed } ##
## \text { in the part where } \int \frac { u ^ 2 – 2 } { ( \sqrt 2 u – 1 ) ( \sqrt 2 u + 1 ) } \, du \text { becomes } \int \frac { 1 } { \sqrt 2 u + 1} \, du - \int \frac { 1 } { \sqrt 2 u – 1 } \, du \text { . } ##
## \text { The second one is: } \sqrt 2 \text { is missed } ##
## \text { in the part where } \int \frac { 1 } { \sqrt 2 u + 1 } \, du - \int \frac { 1 } { \sqrt 2 u – 1 } \ , du \text { becomes } \ln | \sqrt 2 u + 1 | - \ln | \sqrt 2 u - 1 | \text { . } ##
## \text { ... and there is not a simpler way. } ##
Likes PeroK
In symbols...
Look up the Fundamental Theorem of Calculus.
You have correctly obtained [tex]
\int \frac{\sin x + \sin^3 x}{\cos 2x}\,dx = \int \frac{u^2 - 2}{2u^2 - 1}\,du.[/tex] But you then obtain the partial fraction decomposition of [itex]\frac{1}{2u^2 - 1}[/itex], which is not your integrand; the numerator is [itex]u^2 - 2[/itex] not 1. So you need a further step first: [tex]\begin{split}
\int \frac{u^2 - 2}{2u^2 - 1}\,du &= \frac12 \int \frac{2u^2 - 4}{2u^2 - 1}\,du \\
&= \frac 12 \int 1 - \frac{3}{2u^2 - 1}\,du \\
&= \frac u2 - \frac{3}{4} \int \frac{1}{u^2 - \frac12}\,du\end{split}[/tex] and now you can use your partial fraction decomposition.
Likes PeroK
FAQ: Integral involving powers of trig functions
What is the general approach to solving integrals involving powers of sine and cosine functions?
The general approach involves using trigonometric identities to simplify the integrand. For even powers, you can use the power-reduction identities, such as \( \sin^2(x) = \frac{1 - \cos(2x)}{2} \) and \( \cos^2(x) = \frac{1 + \cos(2x)}{2} \). For odd powers, you can factor out one sine or cosine term and use the Pythagorean identity \( \sin^2(x) + \cos^2(x) = 1 \) to convert the remaining even powers.
How do you handle integrals involving products of sine and cosine with different powers?
For integrals of the form \( \int \sin^m(x) \cos^n(x) \, dx \), if either \( m \) or \( n \) is odd, you can use a substitution method. For example, if \( m \) is odd, you can set \( u = \cos(x) \) and \( du = -\sin(x) \, dx \). If both \( m \) and \( n \) are even, you can use the double-angle identities to reduce the powers and simplify the integrand.
What techniques are useful for integrals involving higher powers of tangent and secant functions?
For integrals involving \( \tan^m(x) \) and \( \sec^n(x) \), if \( n \) is even, you can use the identity \( \sec^2(x) = 1 + \tan^2(x) \) to simplify the integrand. If \( m \) is odd, you can use the substitution \( u = \sec(x) \) and \( du = \sec(x) \tan(x) \, dx \). In cases where both \( m \) and \( n \) are even, you might need to use integration by parts or further trigonometric identities.
Can you integrate functions involving powers of cotangent and cosecant?
Yes, similar strategies apply to cotangent and cosecant functions. For integrals involving \( \cot^m(x) \) and \( \csc^n(x) \), if \( n \) is even, you can use the identity \( \csc^2(x) = 1 + \cot^2(x) \). If \( m \) is odd, you can use the substitution \( u = \csc(x) \) and \( du = -\csc(x) \cot(x) \, dx \). These substitutions help convert the integral into a more manageable form.
