Integral of [1-(e^(t/a))]^2 | LR Circuit Power
  • Thread starter Thread starter harshasunder
    Integral
harshasunder
[SOLVED] integral problem
hi. my problems an integral which i can't solve. the integral is this-
integral of [1-(e^(t/a))]^2 dt
a is a constant. it came when i tried to find the total power through a LR circuit
not sure at all.
[1-(e^(t/a))]^3
3 [ then? ]
This can be done with substitution:
\int(1-{e}^{t/a})^{2}dt
Let u=t/a and thus du=dt/a, dt={a}{du}.
After expanding the integrand and putting a (the constant) on the outside, it becomes:
{a}\int{e}^{2u}-2e^u+1 du.
Again, if you don't see it already, use substitution on the first part and manually do the other two easy parts.
Let w=2u, dw=2du, \frac{1}{2}dw=du
\frac{1}{2}a\int{e^w}dw=\frac{1}{2}ae^w=\frac{1}{2}ae^{2u}=\frac{1}{2}ae^{2t/a}
The second part is easy:
-a \int{2e^u}du=-2e^u=-2e^{t/a}
The third part is the easiest (I added the constant 'C' here):
a \int du=au+C=a\frac{t}{a}+C=t+C don't forget the substitution!
Summing all of these gives these final answer:
\int(1-{e}^{t/a})^{2}dt=\frac{1}{2}ae^{2t/a}-2e^{t/a}+t+C
hey thanks! a lot. how did you get the integral signs? (the big s) and the proper format?
\LaTeX is what you're looking for go to
https://www.physicsforums.com/showthread.php?t=8997
\int_0^{\infty} e^{x^2}\;dx\rightarrow \int \mid e^{x^2}\mid \lim_{x\rightarrow\infty}=
\sum_{n=-\infty}^\infty \frac{x^n}{n!} = \lim_{n\rightarrow\infty} (1+x/n)^n
You can click on any bit of code and cut and paste it as well. Try these ones.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
