Integral of e^iwt: Solving for \omega & t Values
  • Thread starter Thread starter skateboarding
    Integral
skateboarding
For particle location, perturbation theory, etc, I see the following integral.
\LARGE \int_0^t { e^{i\omega t^'}}dt^'
Where \omega is some constant, or frequency. It says in my text that this is equal to 0 if \omega is not close to 0. My logic leads me to think that when \omega is large, the function oscillates many times between 0 and t, so it's integral is 0. However, when I carry out the integral explicitly, it is less clear.
\LARGE {\int_0^t {e^{i\omega t^'}}dt^'} = \frac{e^{i\omega t}}{i\omega} = \cos{\omega t} + i\sin{\omega t} - 1}
My question is, from the expression above, how to I show that this integral is 0 or close to zero? I think it depends on the values chosen for \omega and t. If t is greater than \omega, the integral should give a small number, and if t is close to \omega, the integral should give some non zero value. Any help would be appreciated.
You made a mistake in evaluating the integral, it should be:
<br /> \LARGE {\int_0^t {e^{i\omega t^&#039;}}dt^&#039;} = \frac{1}{i\omega}\left(e^{i\omega t}-1\right)
Do you see why?
Do you see why?
Oops, forgot the denominator. I think that for large t, This integral becomes a delta function. Still working on it. Thanks.
fixed it
\LARGE \int_0^t { e^{i\omega t^&#039;}}dt^&#039;
\LARGE {\int_0^t {e^{i\omega t^&#039;}}dt^&#039;} = e^{i\omega t}}{i\omega} = \frac {\cos{\omega t} + i\sin{\omega t} - 1
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
