Integral of x*delta((x/y)-t) dx from 0 to infinity
Applejacks01
∫x*delta((x/y)-t) dx from 0 to infinity
∫x*delta((x/y)-t) dx from 0 to infinity = ty*|y|*θ(ty)
Okay, so using the transformation of variables technique via the Jacobian, I see where the |y| comes from. However, using the dirac delta method I have NO clue how that |y| is derived logically. I know that the property of the dirac delta is that, for ex, ∫f(x)*delta(x-a) dx from x = -infinity to infinity = f(a). In other words, we solve the equation x-a = 0 for x. Likewise, we have ((x/y)-t) = 0, solved for x = ty.
So I can see where ty*θ(ty) comes from...but how is the |y| derived?
Thank you very much.
Try using the substitution u=x/y to get the argument of the delta function to look like it appears in the property you cited.
Don't forget that if y is negative you need to adjust the limits in the u integral. That's where the absolute value will come from.
Ok assuming y is positive( it actually is for the question I was really working on)...
okay so u = x/y implies x = y*u. So we have (y*u*Delta(u-t))
we need to convert dx to du
x = y* u
Dx = y du
int(y*u*Delta(u-t)*ydu)
So u = t and we get
y*t*y*Heaviside(yt)
I can see how the y is derived now. Hopefully my logic is perfect in my derivation. Thank you!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
