Integrate acceleration when a = f(v)
In summary, when acceleration is a function of velocity and the variables are not easily separable, such as in the equation a = k + v^2, you can still integrate using the standard integral formula. Alternatively, you can use the separation of variables method by first rewriting the equation as a = v(dv/dx) and then integrating both sides.
Fuergrissa
Mentor note: Moved from a technical forum section, so missing the HW template.
Summary:: Integrate acceleration when a = f(v) when separation of variables is not trivial, ie a = k +v^2
When acceleration is a function of velocity, ie there is a friction force, you would separate the variables as such:
dv/dt = v^2
v^-2*dv = dt
and then integrate.
but what do you do when they are not easily separable, as in:
dv/dt = k + v^2
Isn't ##\frac 1{k + v^2}## a standard integral?
Likes Orodruin and PhDeezNutz
Note that
[tex]a=\frac{dv}{dt}=\frac{dv}{dx}\cdot\frac{dx}{dt}=v\frac{dv}{dx}[/tex]
Or you can just separate as usual to get:
[tex]\frac{1}{k+v^{2}}\frac{dv}{dt}=1[/tex]
Integrate both sides to get:
[tex]\int\frac{dv}{k+v^{2}}=\int dt+C[/tex]
FAQ: Integrate acceleration when a = f(v)
What does "Integrate acceleration when a = f(v)" mean?
Integrating acceleration when a = f(v) refers to finding the mathematical relationship between acceleration, velocity, and time when the acceleration is a function of velocity.
Why is it important to integrate acceleration when a = f(v)?
Integrating acceleration when a = f(v) allows us to understand how velocity changes over time when the acceleration is not constant. This is important in many fields such as physics, engineering, and astronomy.
How is integration used to find acceleration when a = f(v)?
Integration is used to find acceleration when a = f(v) by reversing the process of differentiation. This involves finding the antiderivative of the function a = f(v) to determine the original function for acceleration.
What are some real-world applications of integrating acceleration when a = f(v)?
Integrating acceleration when a = f(v) is used in various real-world applications such as calculating the motion of objects in freefall, determining the trajectory of a projectile, and analyzing the movement of particles in a fluid.
Is it possible for acceleration to be a function of velocity?
Yes, it is possible for acceleration to be a function of velocity. This means that the acceleration of an object can change as its velocity changes, resulting in a non-constant acceleration. This is commonly seen in scenarios involving friction, air resistance, or other forces that depend on the object's velocity.
