Integrating (2/a)[200sin(3πx)sin(nπx/a)] from 0 to a
  • Thread starter Thread starter maherelharake
    Integration
maherelharake
I need to integrate
(2/a) [200sin(3*Pi*x)sin(n*pi*x/a)] from 0 to a. In this equation , 'a' is a constant. I don't have to show my work, just the final answer.
I used a website, and got a result which I have attached. This online calculator does not plug in the bounds. However, this doesn't seem correct to me. I tried to integrate it by parts (to check), but couldn't get it to work. Any help? Thanks.
If you only want to find an answer you can use www.wolframalpha.com and tell it:
"integrate f(x) dx from 0 to a"
where f(x) is your function.
However, it is always good to know how to do stuff by hand. I think two integrations by parts should work.
Ok so what I inputted was this...
integrate (2/a)[200sin(3*Pi*x)sin(n*pi*x/a)dx from 0 to a
I couldn't get it to give me a definite result. It gave me an indefinite result, but I would like to learn how to use this site properly too.
Ohhh ok. Thanks.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
