Integrating Fractions: A Comprehensive Guide
Lodve
I really struggle to integrate this fraction expression:
\int \frac{2}{4x^2+1}
I presume you're familiar with the standard table of integrals?
http://www.maths.abdn.ac.uk/~igc/tch/ma1002/int/node51.html
Here's a list of many common ones, see if you can get it into the right form for one of them.
If you have to work this out by hand, consider using a trigonometric substitution, but choose carefully.
(Hint: the relationship 1 + x^2 = sec^2 for x = tan x)
Yes, I'm fimiliar with some the of standard table of integrals. I think I just change the equation above in the form
\int \frac{1}{x^2+a^2} where a is an integer, so that the integration of the equation would likely be
\frac{1}{a} arctan(x/a)
But I'm not sure if I've done it right.
You chose the right one, try to get it into a form like that.
Thank you for helping me :D
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
