Integrating Using Partial Fractions
Jay9313
This is an arc length problem in three dimensions. I was given the vector r(t)=<et, 1, t> from t=0 to t=1
Arc Length= \int |\sqrt{r&#039;(t)}| dt from t1 to t2
where |\sqrt{r&#039;(t)}| is the magnitude of the derivative of the vector
I took the derivative and got the magnitude and simplified it down to
∫ √(e2t+1) dt
I then set u=e2t+1
I then simplified and substituted until I got to:∫\frac{\sqrt{(u)}}{u-1} du
My professor said to use partial fractions from here, but I'm not sure how to do that.
Try one more substitution to get rid of the square root on top first. Then do partial fractions.
That's not really working at all
What did you try?
I split it up, and it made it worse, and I had to do long division, but I got an answer. It's nasty, but I got an answer.
Presumably, you ended up with something like ##\frac{v^2}{v^2-1}## after the substitution. A good technique to avoid doing long division is to add and subtract judiciously:
$$\frac{v^2}{v^2-1} = \frac{(v^2-1)+1}{v^2-1} = 1 + \frac{1}{v^2-1}.$$
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
